Reverb bleeding
[Closed] Reverb bleeding
4 Users
why is it taking me so long to get the button bled, 15 min's for the system, 1 hour later and still going at the button.
should I be pulling on the syringe, pushing the button and then going off for a cuppa or something rather than repeating the above process 20 times?
Posted : 09/08/2018 11:47 am
i used a bleed kit form epic bleed solutions and followed this vid on youtube-
worked for me.
Posted : 09/08/2018 11:51 am
Sounds like you could be sucking air in through the delicate syringe O ring rather than from the trigger-its easy to overdo suction.
I usually just set post speed to slowest ,attach syringe,push syringe plunger in then push trigger to push syringe out again-repeat this a few times finishing by pushing syringe in ,removing plugging up.
Then I always set speed to fastest to help with internal post lifespan.
Posted : 09/08/2018 11:55 am
I followed this -
took no time at all (not literally)
Posted : 09/08/2018 12:10 pm
