Reverb bleed fluid ...
[Closed] Reverb bleed fluid 2.5 wt ?
4 Users
Hi,
Need to bleed my Reverb tonight, is the super special Reverb bleed fluid just 2.5wt suspension fluid ?
Posted : 12/07/2012 6:56 am
Comes in the same type bottle as all other RS shock oil, pretty sure it is, but not in work to double check.
Posted : 12/07/2012 9:28 am
Yes it's 2.5wt suspension fluid, not hydraulic fluid
Posted : 12/07/2012 12:27 pm
Hmmm, Rockshox came back to me and said it's mineral oil 😕
Not sure now.
Posted : 13/07/2012 5:25 pm
The two are not mutually exclusive.
Posted : 13/07/2012 5:35 pm
Don't follow ?
Posted : 13/07/2012 5:53 pm
Shock oil can be mineral, synthetic, or semi-synthetic, so just because it's mineral based won't mean it's brake fluid/not shock oil.
Posted : 13/07/2012 5:57 pm
suspension fluid, like engine oil, can be mineral or synthetic.
It is just their 2.5wt fork oil though.
Posted : 13/07/2012 5:59 pm
erm i see.
I picked up some 2.5 wt fork oil but no idea if it's mineral etc etc.
Will i die if i use it ?
Posted : 13/07/2012 6:04 pm
reckon you'll be fine. What brand was it?
Also, worth remembering that one companies 2.5wt can be vastly different from another. It's not a standard.
Posted : 13/07/2012 6:05 pm
motorex racing fork oil, 2.5
Posted : 13/07/2012 6:07 pm
I'd be happy with that in mine (well, the wife's reverb)
Posted : 13/07/2012 6:12 pm
Gave it a bleed this morning, still alive....
Seems to be fine. The fluid that came out of it was yellow ish not red like the reverb bleed fluid is.
Posted : 15/07/2012 6:47 pm
