Revelation damper u...
[Closed] Revelation damper upgrade - help please.
4 Users
I have a some revelations with MoCo damper which I want to upgrade. They have 35mm stanchions 29er with 150mm travel and serial number says they are 2017.
I have seen a cheap charger 1 damper for a Pike A1-A2 2014-2017 and I’m just wondering if it will fit?
Or what the part number for a charger 1 that will.
Any advice would be much appreciated!! Cheers
Posted : 30/06/2019 10:54 pm
Forgot to mention they are boost spacing.
Posted : 01/07/2019 2:34 pm
Have you tried putting your serial number in the rockshox trail head webpage? It should then tell you all available upgrades and the part numbers.
trailhead.rockshox.com/en/
Posted : 01/07/2019 4:03 pm
Cheers for reply, I have tried that but it just gives the part number for the most current charger 2 and 2.1 dampers.
Seen a couple of charger 1 dampers going for cheap so thought I would give one a go if it fit.
Posted : 01/07/2019 7:09 pm
Just get the Charger 2.1 damper - it’s not expensive if you shop around (Bike Discount is usually cheap) and it’s a better damper all round.
Jp
Posted : 01/07/2019 7:27 pm
I thought the charger 1 dampers had a different thread to the newer forks but then some of them might have been compatible depending on boost / non-boost.
Cheers for the reply’s, maybe I’m looking for something that doesn’t exist!! Will look at getting a 2.1. Thanks again
Posted : 01/07/2019 10:39 pm
€140 on Bike Discount if you're OK with Charger 2. €200 for Charger 2.1.
JP
Posted : 01/07/2019 10:53 pm
Cheers for the heads up JP, is there much difference in performance between the two?
Posted : 01/07/2019 11:25 pm
