Reusing Spokes? - g...
[Closed] Reusing Spokes? - good way to save money - or a shortcut to A&E?
10 Users
As per title.
I have a rim to replace - what's the view on reusing spokes? Currently got very thin double (?) butted one's that may cost a few bob to replace.
Posted : 15/12/2009 11:00 am
If you're rebuilding on the same rim, just tape the two together, detension the wheel and swap one spoke over at a time, sorted.
Posted : 15/12/2009 11:02 am
just check the ones around the caseete to make sure there's no gouges in them otherwise you'll be fine.
Posted : 15/12/2009 11:03 am
As long as they aren't damaged they'll be fine. I've done it. I'm still here, and my wheel is still fine too. 🙂
Posted : 15/12/2009 11:07 am
Absolutely fine so long as the spokes haven't been run loose.
No problems at all providing they're not damaged. I'm running on spokes that are 3 rims old on my back wheel 🙂
I don't find it a problem with good quality spokes (eg DT Comps), some OEM spokes are a different matter though.
Posted : 15/12/2009 12:17 pm
spokes out last rims fact i would and have reused spokes
Posted : 15/12/2009 12:30 pm
 IA
As per njee20, done it a few times. Commonplace for DH where you often want to swap out a buggered rim.
Posted : 15/12/2009 1:21 pm
Never done owt else in nearly 20 years of mountain biking. You'll be reet.
Posted : 15/12/2009 1:36 pm
Thanks one and all - good to know.
Saved a few quid - think I may spend it on the odd dram!!
Posted : 15/12/2009 6:48 pm
