Last November invested in a Garmin Fenix 6 and became very interested in effect of alcohol on rest and its (poor) relationship with recovery, measured stress etc. Resting heart rate historically has been in mid 60s/ low 70s. Having largely cut out alcohol over last few weeks and upped activity and excersize, resting heart rate has very gradually came down so now during evenings and sleeping its reduced to mid 50s bpm. Im fit enough, age 57 but a clydesdale. Wondering if time for a checkup as that seems a tad low for a more mature chap with a bit of a weight problem, albiet it fit and active? Any thoughts - similar storys?
perfectly normal IMO Yo have got fitter so resting heart rate drops so long as your BP is not dropping it will be fine - do you get faint when yo stand up?
nearly 57 here. REsting rate currently just over 50, just under while sleeping
I'm relatively thin, mind, but not really "trained" in a meaningful sense
Alcohol definitely pushes it up
(addit: I assume last "few" weeks is too short for much of a trainng effect, but maybe that too)
My crew mate at work is 52, 6’7” and a bit of a chunky roadie.
His resting heart rate whilst sleeping is 37!!
ps yes feel fine - not faint or anything had BP checked a few months ago and was high side of normal range if anything, recently had bloods checked and was ok re glucose etc, cholesterol slightly high but normal range
Sounds pretty normal. I'm 63. RHR around 50-55 but 45-50 when sleeping.
Hardly a racing snake, my BMI is above the recommendation.
stuart, i will swap you mate. mine has been sat at 120 bpm since october. heart doctor says with my meds it will be fine until they can get me in to try and sort it again.
keep well mate.
but a clydesdale.
So am I, 52, same progression, 48-50 resting HR, no issues
Good luck, I couldn't imagine living with that is easy ATM
My thoughts are that seems entirely normal.
I'm 52 and mine is ~51. 6' 2" and 85kg. Mine's gone up 11 in the past 10 years from around 39 bpm
Seems ok.
I'm 52 BMI 25.5 (I know rubbish indicator)
Rhr low 50s drops to mid 40s when sleeping (a good sleep) I can spot a cold coming as it rises to mid upper 50s and booze has the same effect.
This not a good thing then? BP always fine when checked, a bit high sometimes with white coat syndrome. Or cute nurse syndrome, depending who does it.
Same age as you, but my resting HR is usually mid-40's.
I'm not chunky though, and my usual range when riding is 80-170.
Keep off the booze, lose weight and hopefully it'll improve.
sounds ok to me, i notice my heart rate will be a good 10-15bpm higher for a few days after a night of beer from my regular mid 40s,
Sadly for you, I think TJ has retired.
probably nothing to worry about. Although worrying about these things isnt good so the general advie if if your stressing about it see the GP.
on the flip side mines moved from 55rhr to between 80-90 over the last week. Im hoping its just a cold or something.
Did he not keep the costume?
Well, a shift like that is certainly something!
Indicates low blood pressure.
I've just turned 50, am overweight but fairly fit, resting heart rate is 48-50. OP, I'd say you're fine. If anything, keep going and see if you can get it lower.
Don’t know about that. My resting HR is around 56, and for years I sometimes feel dizzy if I stand up quick. My BP has been tested several times over the years and is at the top of the range for being ok.
Just like 'athletic heart', postural hypotension is a thing in some 'trained' individuals.
Like most the syndromes it's a sliding scale and pathologies of what constitutes a syndrome are pretty low based on how unhealthy the general population actually is.
low BP / postural hypotension is not usually treated in the UK although it is in other countries
I run lowish bp - average in the area of 110 / 50 ish I have postural hypotension ( which could have different causes) I have 3 times passed out and smacked my head on stuff so it can be dangerous!
I have once seen a reading of 70 / 40 - I didn't feel great that day ( dehydrated I think)
IIRC ( and I am pushing the limits of my knowledge) postural hypotension is not always connected to low baseline BP
Just my experience - drinking definitely affects my resting heart rate, as does stress, lack of decent sleep etc.
52 yo here, not too chunky and very active, but could do with losing 3-4kg. Resting heart rate average for the last week is 47, also measured with a Fenix 6. It's never been seen as an issue, although I always get pinged by my annual ECG as having intervals that are too long (which just comes with that heart rate)
I've no idea what mine is at. Chance to check it later today if remember. I was told years ago i have a naturally slow beat. But that was years ago.
Aged 54, about 14 stone,6'3", though i used to be 12stn up until about 2 years ago.
I dont drink, but do smoke like a chimney, and eat far too much cheese, though i dont eat meat with fat on it. I dont eat a lot of bread, so butter isn't really a thing for me either.
Plus I cycle, occasionally
I'm not sure about that, we do treat it here, but usually only if it's giving people proper symptoms like passing out and/or falls. First line treatment is just to increase fluid (+/- salt) intake for most people anyway, though there are some drugs we also use from time-to-time.
But unless you're falling regularly, it's probably nothing to worry about.
IIRC (and I am pushing the limits of my knowledge) postural hypotension is not always connected to low baseline BP
Yeah, this is true to an extent. The body's ability to adapt to a change in posture (by vasoconstriction) is modulated separately from control of BP. In fact, there is a group of people with both orthostatic (postural/standing) hypotension and supine (lying) systemic hypertension (sometimes called SH/OH) which is, as you can imagine, quite difficult to treat.
@ OP: If you didn't have a fancy new watch, would you have any idea your heart rate was low? That's as close to medical advice as you're getting from me 🙂
Cutting alcohol definitely has an impact on my resting heartrate increasing by up to 15% or so (there is overlap with lack of sleep also increasing heartrate)
Have you lost any weight as well if you are exercising more and eating less? Since that can also result in a drop.
So wouldnt be something I would be fussed about unless you had some other symptoms eg feeling faint when standing etc.
I’m 62 and have had all the heart tests etc after my blood pressure was high, no issues seen.
Mine is usually about 48 when I wake in the morning, GPs said OK as long as it raises to normal levels once you are active.
Great response thanks- thats very re-assuring - I was getting a little concerned it was dropping into the 50s and you are correct if I had no fancy watch I wouldnt have noticed
Ton - sorry to hear that mate - hope your well otherwise - need to catch up sometime ling time no see.
To add: biggest wake up call is the data the watch spits out after drinking - I have suspected for a long time as I aged that alcohol was starting to have a big impact on energy levels and general well being - what is alarming is how little of it that it takes to do so. Which is a shame as I like my beer and dram. Beer in moderation isnt too bad - but a few drams and goodbye to a good sleep and energy the next day with substantial increase in rest HR.
Sorry if this derails the thread slightly (or if its been covered) but with regard to getting a headrush when standing up: is this normal or something to worry about?
I'm 40 and have noticed recently that I do sometimes get a small headrush when standing up but couldn't decide if a) this always happened and I only just started noticing it, b) its just because I'm getting older or c) I should look into it...
I feel like I'm reasonably fit but no idea what my blood pressure would be.
@duggan I've had similar over the last 5-10 years (I'm 50 now), it feels what I imagine vertigo feels like - massive dizziness when standing sometimes, even lying in bed and rolling over causes it. I went to the docs and he couldn't figure it out - blood pressure was fine, did bloods and didn't find anything other than low vitamin D. For me it comes and goes and having scrutinised it over the last 10 years I think it happens when I am particularly run down and tired, I've also been a lot less fit for a large part of that time.
I've been a lot more aware of it for the last 2-ish years and I don't think it's happened for about a year now, coincidental or not I have no idea but I've been trying hard to get back to fitness and a healthier diet.
I had higher BP after Xmas excess and Covid. If you care, or wanna measure BP as well as HRM a BP monitor (rebranded Omron) is £20 at Boots.
https://www.boots.com/boots-pharmaceuticals-blood-pressure-monitor-upper-arm-unit-10217394
Ah, time for the regular heart rate thread. I've measured mine as low as 31, no it's nothing to worry about and not particularly important (nor does it make me some sort of athletic superman). I do get a spot of postural hypotension sometimes (@duggan that's the medical term) when I stand up but can anticipate/deal with that fine. If you feel it coming on, crouch down immediately (perhaps go on your knees) for a few secs and then stand up again. Oh, and put down that mug of tea pronto before you drop it!
Generally, I have postural hypotension when my fitness is increasing. It goes away once I settle at a relative stable level. It must be something related to physiological adaptation to a heavier work load
All sounds good OP and I hope you get sorted Ton.
When I was proper fit circa 20 years ago my resting heart rate went crazy low. Mid 20's. Then I started fainting if I chugged an alcoholic drink too soon after serious training - heart rate would drop into the teens and then over I'd go. Ended up on a heart tape thingy recording what was going on. Mild hypertrophic (enlarged heart) issue apparently. Scary at the time.
Resting HR is more genetic than anything I think. 40, decent bike fitness but not anything amazing - mid 40's in the day and can be into the mid 30's when sleeping.
My mother's resting HR in her late 60's is low 50's.
I've wondered if my occasional experience of this is down to dehydration, which could be more of an issue when in "training" mode.
Pretty fit here and my HR drops to high 20's normally when I'm sleeping, but glad to report than I can chug a beer straight after a run without fainting 🙂
Errr,if you're asleep,how do you know what HR is ?
Cos if you are symptom free, and you routinely monitor your overnight pulse, you may be over thinking this a little.
Errr,if you’re asleep,how do you know what HR is ?
Well you see there's these things call fitness watches which have heart rate monitors built into them. 😉 24/7 HR monitoring is very easy these days.
I suffer postural hypotension. Not only does my blood pressure drop when I stand up sometimes, but my heart rate also jumps significantly to counter this
It’s happens more when I am dehydrated, and if my heart rate is particularly low before I stand up
I went to see a cardiologist about it, as I also get a ton of ectopic beats. All of this has happened since I got fit after a lifetime of unhealthy living
Anyway cardiologist scanned my heart and told me it’s structurally sound so absolutely nothing to worry about.
As above, the biggest danger is hurting yourself from falling over if you take a dizzy turn.
So, if you are otherwise well, why are you worried enough about your overnight rate too? I only ask cos I've worked in a lot of medical high dependency units, including on nights, and if I felt well, there is no way I'd monitor mine, a my HR if I wake can be quite high, cos I have quite vivid dreams, which is just one of those things.
P.S. you are allowed to take the watch off at night .
It's not just the resting heart rate information that is useful. Watches use that alongside beat-to-beat intervals to assess how well you slept, and how that affects your recovery over time. Once it has baselined your stats it tells you whether you can push it or if you should take it easier. Quite useful. After a boozy night it's interesting to see how poorly I sleep and how my heart rate changes.
Yeah it's probably nerdy, but worth keeping an eye on as i get older.
There is also the website called crickles that analyses your exercises from Strava, and lets you know where you fall on the arrythmia risk - helping spot issues properly early
It’s not just the resting heart rate information that is useful. Watches use that alongside beat-to-beat intervals to assess how well you slept, and how that affects your recovery over time. Once it has baselined your stats it tells you whether you can push it or if you should take it easier. Quite useful. After a boozy night it’s interesting to see how poorly I sleep and how my heart rate changes.
Yep the Garmin sleep tracking, body battery, stress, recovery etc are all really good and need the watch to be worn all day, which I have no issues with. Also helps that a vibrating alarm on my wrist is very effective.
24/7 HR monitoring is just another benefit of this. I don't routinely check my sleeping HR but if my resting HR is up by a fair amount then it's being affected by stress, health or something else. Funnily enough, I changed jobs just over a week ago and my resting HR has gone back down to my normal 45ish from 55ish, and yes I was stressed out and always juggling about 5 things at once in my old job.
I wear my Garmin pretty much full time which has wrist based HR measurement and records 24/7, so I have a lot of data available
I know how well I have slept by how I feel in the morning. That and where I wake up. That can also be a clue as to how much alcohol I have had. If there are corpses beside the bed I know its been a bad night
I wear my watch at night so when I wake up for a wee I can see what time it is. The fact it measures my HR, sleep patterns, etc is a bonus. Love a bit of data me, but only look at it occasionally - when I see a thread like this for example
54 here, my resting heart rate is around 58, that drops to around 50 when sleeping unless like last night after exercise it remains in the high 60s.
I don't really know how accurate the sensor is on my forerunner is. I'd never considered using a heart rate monitor before buying the watch, I bought it mostly to record rides (previously done on my iphone).
After exercise definitely, almost blacked out once answering the front door after a hard road ride. Got as far as opening the door, then started sliding down the wall in front a stranger. Recovered before I totally collapsed. He was a bit worried!
My resting heart rate is around 39-41 and that’s not while I’m asleep, as I charge my I watch when go to bed, ps I’m 51, I’ll leave it on a few nights to see what it says, but I remember only 3/4 year ago it was around 33/34 while I was asleep
Not sure it's been mentioned, but RHR also varies considerably depending on your posture - highest standing up, medium sat down, lowest prone, presumably because your heart isn't having to work as hard overcoming gravity when getting blood to your brain. Mine is currently high 40s stood up first thing in the morning and checking HRV, during long covid it was often double that. I don't monitor HR while I'm asleep, but logically it'll be much lower. It's low 40s just sat down. Mix of genetics, fitness level and stress of all kinds on the body no?
I had covid a couple of weeks back (I assume Omnicron) - my resting HR didn't shift a single beat for the 9 days I tested +ve!
Was very suprised, expected to see a small, eg 1-2 bpm, rise - but absolutely nothing.
Try adding electrolytes to whatever you drink during or after riding. This has made mine all but disappear.
