"Resin pads on...
[Closed] "Resin pads only"
6 Users
So says the rotors on my SLX brake set. Anyone chosen to ignore the advice, used sintered pads, AND survived the experience?
Posted : 12/01/2014 5:33 pm
Yeah. I have them on one bike. They just squeal a lot.
Posted : 12/01/2014 5:45 pm
Sintered pads will warp them....eventually.
Posted : 12/01/2014 5:48 pm
yet more reason not to invest in the most overhyped brakes on the planet.
Posted : 12/01/2014 6:32 pm
 mboy
Those rotors that say resin only on them come with some OEM bikes to cut costs. They are made from a much softer steel than the more expensive rotors. If you use them with sintered pads, the rotors wear/warp alarmingly quickly and they make a lot of noise in the process!
Posted : 12/01/2014 6:40 pm
Forgot to say when you say SLX brakeset...that may not mean the rotors are. My old bike came with SLX 'brake set' but the rotors were RT51 resin only.
Posted : 12/01/2014 7:17 pm
It used to be you got that with deore and lower, but not with slx and up, have they changed that? (or as above, is it an oem set?)
Posted : 12/01/2014 7:45 pm
