Replacing spec endu...
[Closed] Replacing spec enduro rear axle
4 Users
I'm fed up with the twist-really-hard-and-fail-to-get-undone-again rear axle on my enduro.
Is it possible to replace with this one which has a lever mechanism instead? or is there a reason why that won't work?
http://www.bike-discount.de/en/buy/shimano-e-thru-e-thru-lever-axle-rear-sm-ax76-12-x-142mm-272025
Posted : 14/10/2016 8:48 am
Thread pitch is probably the biggest issue.
Posted : 14/10/2016 8:52 am
is the pitch different?
Posted : 14/10/2016 10:34 am
 a11y
Try this
https://robertaxleproject.com/what-axle-do-i-need/
Proved helpful when I was working out what axle I needed for my Genesis HT (different to my 2014 Enduro). From memory I think my Genesis has the Shimano axle you’ve linked to, so no, I don’t think it’ll fit your Enduro.
TBF I’ve never had an issue with tightness (or coming lose) of my Enduro axle.
Posted : 14/10/2016 10:53 am
Thanks!
I did. Rode it as it arrived from the shop which I assumed was tight enough. It subsequently developed play and then the freehub bearings exploded. Now I make damn sure I tighten it well, though sometimes fail to get it undone again without an old seatpost to use as a cheat stick.
Posted : 14/10/2016 11:13 am
This years Enduro has done away with the leaver and its now an allen key job to get it out. The Stumpjumper has gon the same way. Its even a different thread to the looks the same DT Swiss one.
Posted : 14/10/2016 1:00 pm
