replacing a Hope fr...
[Closed] replacing a Hope freehub body - HOW MUCH??!?!
10 Users
after years of abuse, the freehub body on my Hope ProII looks like it's been mauled by a rabid premenstrual badger.
I was amazed that they cost £55 to replace. this seems extraordinary to me. is there a cheaper way of doing it? or an alternative solution? I will probably just file off the burrs and gouges and risk not being able to get the cassette off rather than spend that much.
Posted : 29/05/2013 12:08 pm
Given the price of the hubs now and the amount of machining on the freehub it 'feels' about right.
opt for the steel one as a replacement?
I do just file the lumps off if the do occur, though,
Posted : 29/05/2013 12:10 pm
Sounds about right tbh...
Posted : 29/05/2013 12:12 pm
Use a cassette with an alloy carrier to lessen/prevent damage in the first place? That may be just as expensive in the long run though! 🙂
Posted : 29/05/2013 12:13 pm
I don't know why Hope don't put steel inserts in to the freehub like American Classic do, it stops the cassette chewing through the freehub body.
Posted : 29/05/2013 12:21 pm
I think the last time I replaced a freehub body was on a Shimano hub about 20 years ago and it was about £15. this seems disproportionately higher. do you pay more for the Pro II noise?
I use an XT cassette so the gouges are from the smallest few cogs that don't sit on the carrier.
just remembered that I have a spare Hope wheel so I guess I could steal the freehub from that....
Posted : 29/05/2013 12:22 pm
When you consider its £16 for a set of bearings for the wheels, and there are 4 in the freehub, its actually pretty cheap. Does it include a new set of pawl springs too? If so then even better, especially given the 'Years of abuse' they can take.
Posted : 29/05/2013 12:24 pm
I believe American classic have some sort of patent on the insert. I've heard of people using carpentry staple though.
£55 does get you three new bearings and a set of pawls and springs though.
Posted : 29/05/2013 12:26 pm
even if the price is justified, I can't justify spending that much on a wheel for a second mountain bike that won't be used now apart from pootles in the park.
Posted : 29/05/2013 12:30 pm
Out of interest do people follow to torque setting for the casette lock ring. I was amazed how much it was. As I've only put a casette on I can't say if it helps. But it should prevent movement and damage?
Posted : 29/05/2013 12:31 pm
I don't, but no matter how tight it was it wouldn't stop all play between the cassette and freehub splines. it only needs a small amount of movement to start gouging.
Posted : 29/05/2013 12:42 pm
No you don't need anywhere near the official amount.
Posted : 29/05/2013 12:45 pm
I should have one spare shortly- upgrading a wheel to Evo spec, once I have all the bits anyway. It's worn but not worn out, so if you don't mind waiting...
Posted : 29/05/2013 1:18 pm
if you don't want to keep it as a spare then that would be amazing!
if you remember at that time and want to drop me an email we can arrange something I'm sure. 🙂
Thanks!
Posted : 29/05/2013 2:33 pm
