Replacement Schrade...
[Closed] Replacement Schrader valve core (high pressure)?
2 Users
So I have a leaky Schrader valve in my canyon shapeshifter thing. I'm sure Canyon would sort it out, but replacing a valve core is very easy so I'll just DIY. Anyway, it's quite high pressure (15+ bar) so I don't know whether all valves (eg from old inner tubes) are suitable, or are some made for higher pressures?
Does anyone sell high pressure schrader valve cores?
Posted : 29/05/2016 5:57 am
Any out of my old schrader tubes. Never heard of high pressure versions.
Edit
That's only 220psi,used inner tube ones in fox shocks before at similar pressure
Posted : 29/05/2016 6:07 am
Yeah, I've replaced Fox ones with inner tube versions and it's fine, but I never tried using >200psi. Whereas my Monarch shock and the Shapeshifter both require upwards of 240psi.
Guess I'll try one out of an inner tube and see what happens.
Posted : 29/05/2016 7:08 am
I've had over 250 in older fox shocks before and a quick Google says a metric **** tonne more than that is possible
http://www.spudfiles.com/pneumatic-cannons/topic19296.html
Posted : 29/05/2016 7:18 am
