Anyone know of what pads to get for TRP Spyre's? Thye are on my Spez Diverge. Thed retaining spring has somehow destroyed itself after riding in deep mud etc. I have seen you can use Shimano 525's...
I have some sintered RWD ones that seem to work quite well and are quiet.
While we're here, do your pads have much rotational play in them?
Thye will do if the springs bust!
Uber bike for pads
Found this on chain reaction
The added bonus is that this brake is compatible with Shimano M525/M515 pads, which allows for multiple pad compounds to be used.
The brakes are good, but the spring seems to have bent back on its self and worn away, never has this on hydraulic before. The pad has been gouged away, but the rotor seems unmarked
Used Swiss Stop sintered on mine.
A lot better than the original pads but a bit pricey!
Thanks,
Max
They do look good the Swiss Stop; what makes them better apart form being green?
Über bike race matrix. Best pads I've used on my trp hyrd.
Cheers all, sintered or organic?
They are going on a carbon fork, do sintered make alot of noise?
You don't get the spring clip with uberbike I don't think.
The genuine shimano are probably your best bet.
