Replacement jockey ...
[Closed] Replacement jockey wheels for SRAM mech
9 Users
 rhid
Can someone recommend some of the above please?
It's an 11sp mech so I think they need to be 12t. The ones on the mech are very sloppy and need replacing! Plus the bearings or bushings on the originals seem to be poop.
Posted : 19/01/2018 9:04 am
This is a fairly common subject, quite a few recent threads about it. Other than suggesting do a search I've no recommendations as I've stuck with Shimano.
Posted : 19/01/2018 9:27 am
interested to hear the outcome as mine I have been shot for about 18 months lol
Posted : 19/01/2018 9:35 am
Search for the SRAM NX jockey wheels, same number of teeth, same narrow wide pattern, but bushings instead of bearings so won't seize as quickly, and a quarter of the price.
Oh for the days of wearing jockey wheels down to throwing stars!
Posted : 19/01/2018 9:39 am
Been running a set off these since the SRAM ones in one of our mechs packed it. Not had problem since
[url] https://www.uberbikecomponents.com/category/496/Uberbike-Made-In-Sheffield-SRAM-XX1-XO1-X1-11-Speed-Compatible-Jockey-Wheels [/url]
This code may still work JANSALE25
Posted : 19/01/2018 10:13 am
Sram NX or some kind of alloy ones off ebayseemed to be the consensus on the other thread about this.
Or you could put new bearings in your existing jockeys if the teeth are ok. I forget the size but it's written on the bearing seals and they're cheap to buy.
For now I pulled the seals off the bearings and cleaned them out hen rammed them full of grease and they're going ok to far. Might order up spare bearings shortly for when they seize up again.
Posted : 19/01/2018 10:41 am
My original SRAM ones lasted 5mins on my CX bike, i brought the pricey Hope ones and they're doing fine in the grime.
Posted : 19/01/2018 11:05 am
this
but this
I pulled the seals off the bearings and cleaned them out then rammed them full of grease
has got me through this season. My CX bike has a non-clutch Rival 11spd mech which cost less than replacement jockey wheels (but does seem very prone to clogging so I might end up trying a newer clutch mech at some point).
Posted : 19/01/2018 11:16 am
2 CX races and a few rides and mine are already on their way. Although, I used to find that they'd seize, but then spin well when free again, will see if these do the same (and have some backups ready just in case)
EDIT: looks like NX and Apex share the same jockey wheels, so that would explain why mine (Apex) are coming back to life. Old X9 used to behave in a similar manner with bearings though...
Posted : 19/01/2018 11:19 am
What is it about CX that's so hard on hockey wheels compared to mountain biking? I've literally got no experience of CX and just curious really.....
Posted : 19/01/2018 11:26 am
Mud like you just don’t get on the MTB, as you wouldn’t keep ploughing on as hard as possible. But also grass, which the mud can then really get a grip of
Posted : 19/01/2018 11:30 am
Grass - can imagine that's a nightmare wrapped round everything. I think I'm happy to avoid CX!
Posted : 19/01/2018 11:39 am
You wouldn't beleive how long it takes to get a CX bike properly clean again 🙁 Hope I'm never good enough to need 2 of them!
Posted : 19/01/2018 11:40 am
I wondered that joebristol!
Like legend says, I think it is the combination of everything getting truly encased in wet sticky mud whilst the rider keeps pedalling, I reckoned the pedalling action probably drew the water right into the bearing.
The type of mud probably doesn't help either, it's not the watery puddley mud you might get on a well used trail, it's the sort of 'freshly churned up field' mud that several hundred riders churning round the local park can create. Much stickier and fresher...
Posted : 20/01/2018 3:23 pm
