Anybody know where can get a replacement? Got back from the Lakes to find my lever missing.. Add to that my shifter falling apart and my shock giving up the ghost, it was an expensive weekend 🙁
crappy DT levers.
Im thinking of trying the novatec ones - only source I can find is cyclingdeal.au though...
Yep, spotted that, do you know much about them?
Superstar maybe?? something like this?? [url= http://superstar.tibolts.co.uk/product_info.php?cPath=32&products_id=405 ]http://superstar.tibolts.co.uk/product_info.php?cPath=32&products_id=405[/url]
NOTE- Does not replace maxle type axles
That's a bit confusing!
Emails sent to Novatec & Superstar
I'm not sure about the dt Swiss axles but if they're the same as the maxle axle then the superstar won fit. The thread pitch is different. Betd do an intense axle that suitably replaces a maxle axle.
Ta, emailed them too.
Superstar, BETD & CRC are all a no.
Emailed Nukeproof.
Is it definitely 12x135? according to their website DT Swiss don't do a 12x135 thru axle.
[url= http://www.dtswiss.com/Components ]http://www.dtswiss.com/Components[/url]
Sure it's not 10x135 or something
[url= http://www.chainreactioncycles.com/dt-swiss-rws-thru-bolt-alloy/rp-prod81162 ]http://www.chainreactioncycles.com/dt-swiss-rws-thru-bolt-alloy/rp-prod81162[/url]
What bike is it off?
Nukeproof Mega
It's from a few years ago, not the current one.
I'm sure Mugboo will be along soon...
This might be it
[url= http://www.madison.co.uk/products/cycling/wheels-complete-wheel-spares/axels/rear-axle-for-fr-440-hub-135-x-12-mm-bolt-thru/ ]http://www.madison.co.uk/products/cycling/wheels-complete-wheel-spares/axels/rear-axle-for-fr-440-hub-135-x-12-mm-bolt-thru/[/url]
Thanks Simon. Yep original Nukeproof Mega.
Cheers Dango, so they use a nut rather than the thread in the dropout?
Ta Paul, I'll email Madison & have a chat with Barry Firth, he might be able to order one. I might yet be able to fashion a lever on to axle, it's just that that's gone AWOL.
I'm suspecting that (as per Dango) it'll turn out to be one the these axle designs that are now advertised as 12x142, because that's what the manufacturer currently sells as a hub/dropout/axle system. The 135/142 dimension is the internal dropout measurement, but all of them are 150 external dropout measurement. It almost doesn't matter about 135/142, it's the design of the end bits, Syntace X-12 design, Sram Maxle design, E-Thru, camming action of axle, thread length of axle, external dropout inserts and/or machining, threaded dropout(X-12). I'm thinking it could be E-Thru, it looks to me like E-Thru is everyone elses version on the Sram Maxle, the fact that they all state 12x142 for E-Thru might be a red herring as that's just Hub and internal dropout design. I might be wrong tho.
Let's see what Madison & Nukeproof say. As you say, it's only 7mm difference...
Madison say I can order it through my LBS. Barry will sort me out. Cheers one & all.
£35 from LBS for a new DT Swiss one.
