My bike came with a Truvativ 3.3 GXP crankset, which initially was fine.
After 5 years I have replaced all the chainrings, bottom bracket twice (first time GXP, 3 months later a Hope BB) and the self extracting bolt has cracked. Nothing unexpected for the use/age.
Last year however the LBS discovered the self extracing crank bolt was cracked, so kindly fitted a rubber sealed plunger type bolt (not self extracting). I pretty much have to tighten the bolt up every other ride and it seems to wear loose very quickly.
Shall I either: replace the crank arms only and retain the middleburn chain rings or ditch the whole lot and get a new crankset from shimano (which I hope will be more secure). Also, is it best to leave my Hope BB in place - I can't seem to get the bugger out anyway, despite adding grease when I fitted it, it feels locked in place. Presumably a Shimano set up would slide stright into a Hope BB (once I have removed the SRAM type GXP adaptor).
Any recommendations?
Oh, meant to say it is a 3 x 9 set up with standard 68/73 mm bb shell.
Thanks Redted, but probably looking to go away from truvativ to another brand. I will probably transfer old chain rings onto new cranks to keep the new rings fresh and wear all the old stuff out together before using up newer rings.
Shimano Deore HT2
CRC have OE ones, with BB,for sale at £48 right now, which cannot be beaten..... Well, last week they were £25. I bought one, my brother bought 3, but you get the idea! 🙂
My GXP crankset lasted one change of bottom bracket before I could no longer tighten it enough to stay on longer than 30 minutes. Same with a friends one. All my shimano cranksets have had no problems.
Jsinglet - glad it is not just me then, I began to think I was doing something stupid.
Got back from riding around Surrey Hills yesterday evening, the left crank arm was literally floppy as it was so loose.
Time to change to Shimano me thinks. At least I know it will just work.
