repairing (stainles...
[Closed] repairing (stainless) steel frame
4 Users
I have a frame made from KVA MS3 Stainless, and I've recently found a crack, if this was any 'normal' steel I'd be off to my local tame welder* for a repair but I confess to not knowing much about stainless, does it need any special consideration or equipment?
*yes I will ask him but currently on holiday!
** also off to read on KVA website...
Posted : 03/09/2018 4:46 pm
If you're willing to search through his videos, Jodie at Weldingtipsandtricks on Youtube has tons of useful info regarding techniques, gasses, purgeing, and material selections. I only do occasional mig welding, but i'll watch hours of his videos just because they're interesting.
Posted : 03/09/2018 8:01 pm
You can weld stainless with a range of processes, I would TIG with a back purge personally.
You need to find out what KVA MS3 is so you can select the correct filler.
Posted : 03/09/2018 8:40 pm
<h3> http://www.kvastainless.com/bicycles-frequently-asked-questions.html</h3>
<h3>Welding tips:</h3>
  • Clean and prep all tube ends before welding with dedicated Stainless steel wire brushes, abrasive pads, or sand paper.
  • Use Acetone for removing grease or oils.
  • Stainless steel filler wire ER631, ER309L, 308L, 312L, Weldmold 880/888, or ER630 (17-4PH) are recommended for all joints - to steel, other stainless and KVA STAINLESS™ MS3 tubes.
  • Back purge with Argon gas at 15cfm. Back purge during tacking Purge for 2-5 minutes before welding to ensure a 100% purge.
  • Post-weld tempering optional for improved fatigue performance (350-400° F for 20-30 min).
<h3>Brazing tips:</h3>
  • Stainless steel lugs & braze-ons (type 304, 316 or 17-4PH) are recommended with 0.002-0.004” radial clearance.
  • Low temp silver brazing alloys: Aufhauser Silver Alloy A-56T®, Harris Safety-Silv 56®, Harris Safety-Silv 45®, Fillet Pro® or equivalent recommended for minimal effect on tube strength. Liquidus temperature of braze alloys should not exceed 1400° F (760° C).
  • The joint surface areas should be clean and free from oil, grease, or oxide contamination.
  • Brass and/ or nickel brazing <span>not</span> recommended!!!
Posted : 03/09/2018 8:45 pm
Ms3 is just a precipitation hardener , think of it like 7000 series aluminium of the steel world
From memory 309 filler was the popular choice but most people will go to 312 for repairing stuff .
Posted : 03/09/2018 8:51 pm
