Hi all currently waiting for my forks to arrive they are currently set @100mm Reba's I want to remove travel spacer .can anyone advise me best way of doing this (first time) .....can I save oil or do I have to replace as they have just been serviced could do without new oil...thanks
Bump
I used this guide. REad it through so it makes sense, and then go for it. It's a simple operation.
If you keep the lowers sideways and you're careful, you can do it without losing the oil - that said, it's worth drainign the oil and putting in fresh as it's not uncommon for new forks to come without much oil in them
http://www.bikeradar.com/gear/article/workshop-how-to-adjust-travel-on-a-rockshox-trail-fork--26840/
Hi,
Are you sure that you can change the travel on these forks? I know you could do so by removing a spacer on previous models, but i think you need a "kit" to do it on more recent models. Which year and model you have?
