I have an old pair of black Shimano XT cranks with the usual heel rub on it. Is there a quick and easy way of removing the rest of the black coating to make them silver?
Posted : 28/07/2020 9:20 am
Oven cleaner is worth a go. Failing that, wet and dry.
Posted : 28/07/2020 9:48 am
bit of wet mud and the heel of your mtb shoes.
Posted : 28/07/2020 10:23 am
I used caustic soda to remove the anodising before polishing up an old set of Saints, came up a treat!
Posted : 28/07/2020 10:33 am
As said, oven cleaner however I'd be more inclined to go with wet and dry than the chemical route.
Posted : 28/07/2020 10:34 am
I bead blasted mine. Then repainted black followed by helicopter tape.
Posted : 28/07/2020 10:42 am
I've wet and dried in the past, and used metal polish to slowly take of the worn anodising. Chemicals may damage the finish. It isn't quick for a good finish though.
Posted : 28/07/2020 10:43 am
