When pinning on race numbers i'm usually either stabbing myself or moaning about making holes in my skinsuit with safety pins, so this weekend was pleased to have stick on numbers as an alternative. However on removing them there is a lot of sticky residue left and a couple of washes in the machine haven't removed much. Any tips for removing it?
I have the exact same issue. Was this Crit on the Campus by any chance?
Thinking of using some ethanol from work (or meths) and if that fails a bit of IPA. Fairly sure that'll be safe on the fabric.
Just how pleased were you?so this weekend was pleased to have stick on numbers as an alternative. However on removing them there is a lot of sticky residue left
Yeah Crit on the Campus, at the time it felt quite pro just slapping the numbers on. They dont have to clean their own kit afterwards though!
Ethanol generally works better than isopropanol for this purpose. I tend to work in this order: Isopropanol-ethanol-acetone-xylene, if none of those work then forget it!
Petrol lighter fluid has worked well for me on fabric. It even dissolves chewing gum. This was on cotton mind you. I'm not sure how it would react with synthetic fibres.
