Removing Shimano fr...
[Closed] Removing Shimano freehub
6 Users
 teef
Watched a few youtube videos and they say use a 10mm hex to remove - tried it but 10mm isn't big enough. Are there different sizes - what are they?
Posted : 29/05/2016 1:39 pm
If it's a through axle hub it needs a 15mm allen key to remove the freehub.
Posted : 29/05/2016 1:53 pm
11mm if a standard 135mm hub.
Posted : 29/05/2016 5:03 pm
Just buy a set of Allen keys..find one that fits...problem solved!
Posted : 29/05/2016 5:08 pm
Unless you need a 15mm that won't come in a set. 11mm is usually found on Formula hubs, not Shimano, and is more readily found as 7/16"AF.
Posted : 29/05/2016 5:30 pm
I've got a Formula that needed an 11mm and that was a pain because it's not in a normal set. Cost a fair bit for one though I did get a big sturdy decent quality one. Found it hard to find places with them in stock at the time.
Posted : 29/05/2016 5:36 pm
Yep, very few tool shops will stock an 11mm, but often have the identical 7/16"AF .
Posted : 29/05/2016 6:20 pm
