Removing main swing...
[Closed] Removing main swingarm bearing from Saracen Ariel
6 Users
Help!
Got some play in the main bearing of my Ariel (to be fair, they've out lasted about 5 sets of Norglide bushes...).
Problem is, the axle just spins. Anyone confirm that 1. It's NOT a left handed thread? 2. That there isn't a knack to it like taking out the little conical shim thingy.3. That is is actually possible.
Pics below - one side has a 6mm hex hole in it, the other seems to just be a circular hole.
This just seems yet another complication in the world's most badly designed frame 🙁
[url= https://photos.app.goo.gl/HpFLaJaqw1oATT5w2 ]Round hole[/url]
[url= https://photos.app.goo.gl/uEpCBM6TtnHnXTJj1 ]Hex hole[/url]
Posted : 17/11/2017 7:13 pm
I can't answer either 1 or 2 I'm afraid, but the axles for the bushings on my Kili Flyer were completely seized up and the bolts stripped in the end.
The LBS sent it back to Sportline who promptly returned it with new bushings fitted... so that might be an option if you don't get anywhere?
Posted : 17/11/2017 7:31 pm
I've admitted defeat and put it into the shop. We shall see...
Posted : 19/11/2017 5:56 pm
Update for anyone searching for this issue, definitely a warranty job, unless like me you're the second owner in which case it's probably beyond economic repair 🙁
Posted : 22/11/2017 7:22 pm
What's broken then to make it beyond economic repair?
Posted : 22/11/2017 8:02 pm
 RicB
Can't you just Dremel a slot in the 'hole' end of the axle to get some purchase with a big screwdriver?
Posted : 22/11/2017 10:13 pm
Can you use an easy out. It’s a tapered come thing with a twist so it bites in as you turn it anti clockwise
Posted : 22/11/2017 11:23 pm
its not a left hand thread. sounds like the bit you refer to as a conical shim has come loose from the carbon, its meant to be fixed as it is the nut for the axle effectively.
Posted : 23/11/2017 8:44 am
Yup.bonded in threaded cup but is no longer bonded meaning new rear triangle is needed. Possible repair option but I'm not optimistic...
Posted : 23/11/2017 8:26 pm
