Looking at some Renthal Farbars but not keep on the bold white decals. Is it possible to remove them?
I'm sure the last time this came up someone said acetate. It's definitely been discussed though.
Acetone, not acetate. 😉
Nail varnish remover.
Sharpie
Will acetone not damage the finish on the bars?
It shouldn't but you could test it where one of the grips will cover it anyway.
Sometimes the decals are under laquer. Fine fine sandpaper and quick spray of lacquer and polish 🙂
Are they actually decals? I had some that were printed logos or laser etched something that could not be removed
I don't know if they're under lacquer or not. If it's a bit risky I'll just look for some bars the same shape in black.
Pretty sure that's a no.
That's the one! Close enough that someone with something between their ears understood...
Anyway, I found the topic I was thinking of:
