i have just bought some replacement deacls for my mavic deemax wheels but before i make a start is there an easy way to remove the old ones?
thanks
Warm em up with a hair dryer
And then use acetone (most nail varnish removers) to remove any residue and clean it up for the new stickers.
...and when you put them on use a weak solution of washing up liquid. It allows you to move the sticker about and put it EXACTLY where you want it - then allow to dry. Got that tip from a mate who did it for a living before anyone questions it !
You will need:
-1 chisel
-a 500ml bottle of your own urine
-a copy of the Sunday times
-some wire wool
-a 5lb lump hammer
-2 bungee cords
-a dremel
Use the listed items in whatever fashion you like to try and remove the stickers then prepare a “Whoops I’ve buggered my expensive wheelset” post…
WD40 removes and softens the stickiness
White spirit or lighter fluid.
This lifts the glue from the previous sticker.
Job done.
