removing damper on ...
[Closed] removing damper on reba's?
3 Users
Can I remove the motion control damper on my reba's (2010 dual air) without a full strip down (not removing lowers etc.).
Slightly under filled the oil in the damper (should have 123ml, got about 110ml when I rebuilt them). Can I just open it up and top it up now I've got a new bottle of oil? Only been ridden two rides since rebuild hence not wanting to fully strip them if not needed.
Posted : 30/03/2014 7:21 pm
Simple answer - yes! Just unscrew the top and stick some more oil in.
Posted : 30/03/2014 7:24 pm
Oh and I ended up with about 115 ml in mine. If i put in the amount in the service manual, I found I did not quite get full travel. Have about 2mm vertical movement before Lockout so just about right.
Posted : 30/03/2014 7:26 pm
Yep, as said, just undo RH leg. No need to even take the air out.
Posted : 30/03/2014 7:27 pm
Great, thank you everyone 🙂
Posted : 30/03/2014 8:54 pm
