Removing crown race...
[Closed] Removing crown race from forks
20 Users
Have a nice set of forks from my bro waiting to be used, but they've got a crown race on there. What's the bestest/safest/neatest way to get it off of? Thanks.
Posted : 06/10/2010 12:19 pm
I resorted to a big flathead screwdriver and hammer, it wasn't particularly pretty. I did think about using the Dremmel on it but with my skills the chances of not cutting into the steerer seemed slim.
Posted : 06/10/2010 12:21 pm
What he said. And use proper hammer and don't forget to use the North South East West method either.
Posted : 06/10/2010 12:27 pm
best is to use a crown race removal tool, cheapest is flat screwdriver and a hammer. latter likely to damage paint on fork crown a bit though, however careful you are.
Posted : 06/10/2010 12:28 pm
If there is no gap or its small, try tapping a kitchen knife in first and work it around the circumference. Should give you something to tap your screwdriver off of.
Posted : 06/10/2010 12:42 pm
I use a hammer and a bit of hardwood rather than a chisel/screwdriver. Less potential for gouging things and it still works.
Posted : 06/10/2010 12:43 pm
Chinese cleaver and hammer every time
if you want to re-use the race then tap it with something softer than a steel screwdriver. I tapped a King one off using a piece of copper pipe (and the NSEW method to "work" it off) and both it and the fork are pristine.
Posted : 06/10/2010 12:45 pm
it's off. nicely. best way for getting the right crown race on there??
Posted : 06/10/2010 12:46 pm
I use a hammer and large, flat screwdriver. However Ice Toolz do a £20 tol for the job that would do a cleaner and better job of the removal. £20 you'll only have to spend once.
Posted : 06/10/2010 12:47 pm
I use a piece of 4x2 with a 30mm hole drilled in it & a rubber mallet for getting 'em on.
Posted : 06/10/2010 1:05 pm
Having used a mallet and screwdriver on my last crown race, and making a right pigs ear out it (not to mention turning the air blue and marking the fork crown) , I think I'll spend a few quid and get the right tool for the job, makeing life just that bit easier for myself.
http://www.ukbikestore.co.uk/product/38/e251/ice-toolz-crown-race-remover.html
Posted : 06/10/2010 1:13 pm
30mm pvc pipe cut to length makes a great crown race fitter. I've fitted loads of crown races with the same bit of pipe.
Posted : 06/10/2010 1:26 pm
A packet of biscuits and offer to make the tea at your lbs. Proper tool, one whack and it's off.
Posted : 06/10/2010 2:19 pm
 drew
+1 YoKaiser. I put the knife inside a thin plastic/latex glove to protect the fork crown. Most knives have a tapered blade and by working your way round you can make enough space for a screwdriver to fit.
Posted : 06/10/2010 4:01 pm
For getting it on I used 1.5metre piece of iron piping and just dropped it onto the race...it worked
Posted : 06/10/2010 4:14 pm
The plastic tube from a vacuum cleaner works a treat, just the right size, well mine was anyway! 😉
Edit: thats for putting it back on obviously.
Posted : 06/10/2010 4:19 pm
Stanley knife blade first. Then screwdriver.
Posted : 06/10/2010 4:20 pm
lbs, and a few quid.
how often will you use the tool, really?
Posted : 06/10/2010 4:43 pm
 mlke
I bought a crown race removal toy for under £20 from ebay.
It's good to have tools.
Posted : 06/10/2010 6:09 pm
I knock my crown races on using that 30mm plastic tube. Works a treat. I get em off with a screwdriver and hammer or if there is no gap I use an old wood chisel. That works a treat too 8)
Posted : 06/10/2010 6:13 pm
