Look like brazed/welded on ones. Would need to be unbrazed/unwelded I wooduv thought. I spose you might be able to cut them off then grind the weld smooth, but quite a lot of hassle really. And I'm not sure if you'd damage the frame or not; I've seen a bad job done which left the frame pretty wrecked.
Do they have to come off?
Looks like they're welded, in which case you'll have to cut them off. Be very careful not to damage the tubes...
If they were brazed you could get them off with heat alone. Much friendlier 😉
Thats what i thought as there are no flats on the boss.
They don't really have to come off - just think they look a bit unsightly
I've removed a welded pair by hand before. It takes a while 😉 but looks tidy.
Thanks for the replies chaps
Going to leave them for the moment -
D
