Removing bottom bra...
[Closed] Removing bottom bracket on Trek Fuel 9.7 2014
4 Users
Hi all just after a little advice. I've just ordered a dropper post for my trek but need to remove the bottom bracket to install. I've read theyre 'slip fit' so does this mean I don't a specific tool or do I require 'press fit' tools. Just don't want to buy the tools if they're not required.
Posted : 07/01/2015 11:40 pm
From memory, it'll be a "Madone" BB, just bearings pressed into the frame, with a plastic sleeve between them. If it's a carbon frame, they may well almost fall out on their own, but tapping them out with a drift is usually easy. As always, the correct size drifts should make re-fitting easier.
Posted : 08/01/2015 7:18 am
If they fall out on their own rather than drift out then you'll need the oversize BB bearings to get around the problem Trek don't like to acknowledge but do produce a fix for.
Posted : 08/01/2015 7:41 am
Known as V-type in Trek speak, sometimes they're also loose 😳
Posted : 08/01/2015 8:14 am
Yep, no tools required, a slight tap at most is generally all they need!
Posted : 08/01/2015 8:32 am
Perfect. Its a carbon frame so hopefully just pop out. When you say "drift" what do you mean? Any suggestions of what tools to use so I don't damage the bearings?
Thanks for your help.
Posted : 08/01/2015 11:50 am
