removing bb30 adapt...
[Closed] removing bb30 adapter sleeve
7 Users
Have a carbon road bike that is bb30 but has an adapter shell to take normal bb. I assume it is porbably loctited in, any tips for removal or is it likely to be a pita?
ta
Posted : 24/03/2013 12:47 pm
 LeeW
Was it in their when you bought the bike? Could you contact the manufacturer to find out if it is Loctited in?
Posted : 24/03/2013 12:54 pm
Even if it's loctited in as mine was it should still knock out fairly easily using the right size socket and something to support the frame.
Posted : 24/03/2013 1:14 pm
A question on press-fit Bottom Brackets (never had one)..
..are they user servicable or do you have to use a bike shop to replace the BB bearings when they wear out?
Posted : 24/03/2013 1:25 pm
Muddy dwarf, just use a headset press to press it in. My instructions said it would be difficult to remove from a carbon frame. Cant seeing it cant be much different than an alloy one.
Posted : 24/03/2013 1:32 pm
What do you use to get it out, and what are the advantages over a threaded system?
TBH i'm struggling to see the benefits and i fear i'll struggle to avoid a press fit when i buy a new bike.
Posted : 24/03/2013 1:35 pm
 LeeW
It depends on what style you go for, there are several types which have different solutioins. Mine is a 46mm ID x 73mm width. I use a Praxis converter which, when installed looks just like a normal external BB. There are other options for this type which require Delrin spacers which I've not tried.
You can also get a Sram PF to BSA adaptor, you screw a normal BB in to it and press it in the frame. For me, the trouble is it's made of Nylon which I don't hold much hope for in the long term. An Alu one would be great as long as it hade a decent interface in the ctr of the BB shell.
The other type can have have up to a 92mm shell width, there are others but can't remember the exact sizes. Hope make servicable BB's for this type, I understand they're making one for the other style BB shells too. King are releasing something this Spring too.
Other, more durable solutions will come soon. It;s just a matter of time. I hope.
Posted : 24/03/2013 1:50 pm
HIJACK!!!
I have a bb30 on my road bike. I need to replace the BB bearings. the BB is a campag ultra torque. Do I just buy the standard campag bearings? there's no special BB30 bearings are there?
Posted : 24/03/2013 1:58 pm
warton - [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=56024 ]this[/url] would suggest you need normal UT bearings, assuming its that bb you have installed (2nd pic, 1st one is the bb92 version).
Posted : 24/03/2013 2:04 pm
