Remove glue from ca...
[Closed] Remove glue from carbon frame
3 Users
Hi folks. Bought a 2nd hand Mojo HD3 minus metal chainstay protector. Ordered a replacement but previous owner has mibbe tried to glue the old one on a couple of times. Replacement doesn't quite fit properly, not helped by excess glue.
The old glue looks pretty translucent but is on solid- possibly some sort of epoxy. I'm not sure how best to remove it. Dremmel with a fine grinding wheel and just take my time or some sort of chemical method?
Thanks in advance.
Posted : 14/01/2021 3:18 pm
to be safe.. grind, file, sand
if it is epoxy.. so is your frame, what takes that off won't do your chainstay strength much good
Posted : 14/01/2021 3:50 pm
Cheers mate. Wasn't sure but makes sense!
Have I already messaged you on PB about wheels BTW??
Posted : 14/01/2021 4:11 pm
aha yes lol didnt realise it was you 🙂
Posted : 14/01/2021 5:03 pm
Nail varnish remover may help to soften the adhesive but make sure you clean it thoroughly after as prolonged exposure to acetone can damage epoxy-based composites
Posted : 14/01/2021 5:44 pm
Just a gentle grind, file and sand before sticking the plate back on. Cheers folks!
Alan- I'll fire you a message in a week or so btw!
Posted : 15/01/2021 12:00 am
