Looks like this is just a case of adding the all travel spacers, is that right? Is there a ghetto method that doesn't involve paying 15 quid for some tiny plastic spacers?!
Does anyone know what the minimum they can go down to is? From googling I think they're 150 stock, and I currently have 2 spacers in there. Can they go down as far as 100? I can't see any reason why not from looking at the internals on the air spring side.
Fwiw, mine are dual air RLTs I think.
Edit: No, you don't have the same model as mine, ignore.
This is probably the manual you need:
I got mine down to 100mm with spacers but the lockout doesn't work and compression adjustability is limited.
Cheers Hols, I've got the manual already from SRAM, and it shows you how to install them (is pretty bloody clear once they're apart, before you even look at the manual!) However, unless I'm being blind, it didn't seem to specify max number of spacers.
Eulach: cheers dude, that's good news! I think you may have a slightly different model though as mine don't have lockout. Suspect the air spring is the same though. Guessing you used proper spacers? Tempted to try an 'experiment' with some spare RS and fox air spring parts I have.
