Reducing soul build...
[Closed] Reducing soul build weight - fork options?
4 Users
I have a Mk1 cotic soul that i love, but i cant help thinking that its a little on the portly side. Its currently running Pike 454 coil u turns 95 to 140mm forks with 20mm maxle. How much weight could i lose by switching to another set of forks? Are there any good options out there with ~130mm travel and 20mm axle that would offer significant weight saving over the pikes?
Posted : 12/10/2014 6:09 pm
swopping to an air fork will save a huge amount of weight and change the handling a lot
i tried my cotic with a pike 409 coil u turns but hated it and only lasted one ride with them - far too heavy a fork for a steel HT imo, i finally settled with a set of 120mm dual air rebas with a 20mm axle
the problem you will have is buying a new fork that has a 1 1/8 inch steerer, 120-130mm travel and the 20mm axle
imo you'd best try find a second hand 150mm air revelation (with the 20mm maxle) that can have a 20mm travel reducer fitted - so you end up with a 130mm fork that fits the frame and saves you around 550g (1.3lbs) over your coil pikes
most new 130mm forks have a 15mm thru axle
Posted : 12/10/2014 8:32 pm
I had a set of Sektors on mine a few years back. I found them to be to heavy for the bike and made the front end to high and liable to wander on climbs.
I now run a set of 120mm Reba's and think they are spot on. Saved a good bit of weight aswell. I also had the tapered headtube version and ran 130mm X Fusion Velvets which were equally as good as the Rebas. Only wnt for Reba's as Merlin had a cracking deal on them.
Posted : 12/10/2014 8:55 pm
thanks for the replies. 120mm rebas were one option i was thinking about and two replies recommending them as well means i'll go in that direction. Just got to find some now!
Posted : 12/10/2014 9:11 pm
I've got some Revelations spaced down to 120mm on my Sanderson. 20mm axle, stiff, plush, and not heavy.
Posted : 12/10/2014 9:19 pm
