Redshift stem now (...
Redshift stem now (finally) in shorter lengths
6 Users
https://redshiftsports.com/
Just got a notification that they've finally released these in 70mm and 55mm. I'd been in touch with them for a while as knew they'd had shorter stems in development, so good to see they've finally been released. Be interesting to see if the shorter length has enough leverage to make a real difference....
Posted : 14/08/2024 7:57 am
I ABSOLUTELY do _NOT_ need one of those on my road bike. Dammit.
(but thanks for the link)
Posted : 14/08/2024 9:17 am
What sort of bike do you envisage wanting one for?
I've got the 80mm version on a gravel bike. I guess some very off road gravel might have geometry that would work with a stem that short. Probably need very very wide drops for the steering not to feel so weird with such a short stem.
Posted : 14/08/2024 9:27 am
I quite like the idea of a 55 or 70mm shock stem on a rigid 29er. Something that hardly moves but takes the edge off, combined with the tyres and grips it should be enough for a lot of general MTB/ATB riding.
Posted : 14/08/2024 9:47 am
It should be noted that even Redshift in their notes appreciate that the effect of a shock stem on a flat bar bike is significantly less than on a drop bar. You have to put the softest elastomers in there and even then it's not as effective. It's just physics - well, moments. With your hands on the hoods or drop (and a longer stem) your  hands and therefore your input is a lot further away from the fulcrum of the moving part of the stem.
Posted : 14/08/2024 10:24 am
As @jameso mentioned above, I was interested in the 55mm version for my rigid 29er, after rating the 80mm version on my gravel bike. I had swapped out the rigid fork for a Reba on the 29er, but think I prefer the lightness (and pack mounts) on the carbon fork.  The 55mm Redshift might take the sting out of the Ridgeway tracks I tend to do.  Mind you, I run a loop Geoff bar on the 29er so not sure if the stem would work as well with that as the drop bar gravel bike...
Posted : 14/08/2024 6:50 pm
Was thinking about this more. Your average flat bars have some back sweep. I reckon with a 55mm stem the bit of your bars that you hold are about 10mm in front of the stem pivot. I just don't see how it would be in any way effective. Your hands on a Jones bar and a 55mm stem would surely be a good bit behind the pivot so definitely wouldn't work.
I just think a suspension stem this short is a product looking for a scenario Ird actually work.in.
Posted : 14/08/2024 6:58 pm
Just read this on the Redshift website: https://redshiftsports.freshdesk.com/en/support/solutions/articles/9000135435-will-shockstop-stem-work-with-the-jones-h-bar-
Apparently the 55mm and 70mm are intended for drop bar only, & only some forward hand positions on the Jones bar work with the 80mm+ stems.
Still might be useful for a rigid drop bar 29er...
Posted : 14/08/2024 7:36 pm
Oh, I've got an Easton 50mm stem on my road/gravel bike, that redshift one would replace it well as I've just put on some Spesh hover bars which are 5mm shorter in reach.
I might hold on to see if the USE one is available soon, however I don't think it will be offered in that small length.
Posted : 15/08/2024 3:51 pm
It’s just physics – well, moments. With your hands on the hoods or drop (and a longer stem) your  hands and therefore your input is a lot further away from the fulcrum of the moving part of the stem.
Certainly is. I used to have a Flexstem BITD. When I was on the front of the L-bend bar ends you felt a lot more movement. TBH I wouldn't want that movement in a bike with drops but 5mm, maybe 10mm of cush on an MTB in that area could do a fair bit for comfort w/o making the bike feel disconnected.
It wouldn't be good with Jones bars and a 55mm stem, but Jones bars and a 55mm stem is an odd combo to start with : ) With an MTB riser your hands will be close to the steering axis so not a lot of leverage, but the forces between the grips and the tyre have to act somewhere so with a suitable elastomer it should work to some extent. More of a buzzkill than suspension movement.
Interested to try one but not rushing to spend that kind of money to find out.
Posted : 15/08/2024 5:11 pm
Be interesting to see if the shorter length has enough leverage to make a real difference….
Should just be down to the elastomers used right? As noted already though the moment changes based on tops/drops/hood hand positioning, so which do most people 'tune' their redshift for currently? I'd have guessed hoods (longer lever), but I could understand if people opted for more vibrations damping for descending in the drops.
Just how finely can they actually be adjusted?
Posted : 16/08/2024 9:43 am
Very, my Flexstem used to change spring rate depending on just the temperature : )
Posted : 16/08/2024 10:00 am
