Recommendations ple...
[Closed] Recommendations please for a 'bike packing pillow'
10 Users
I bought one of those 'Trekmate' inflatable pillows from Tiso. The outer cover was good, it packed down small enough but I didn't like the whole 'wobbly' inflated thing under my head. I must have woken 4-5 times with a crick (is that a word?!) in my neck before I ended up stuffing the outer with my down jacket and some shorts...worked fine after after that. This worked as the weather was dry so all my gear was nice but if everything was wet then...
Anyone recommend a better solution rather than bringing my own pillow slip and stuffing it with whatever is dry?
Posted : 06/06/2016 1:13 pm
Part full/semi inflated camelback.
Posted : 06/06/2016 1:15 pm
the best solution I found was to stop using a pillow at home 😆
Posted : 06/06/2016 1:16 pm
I stick a fleece in a stuff sac
clothes in a dry bag with a buff over works nicely for me.
0 additional bulk/weight
Posted : 06/06/2016 1:17 pm
Pillows are prohibitive for bike/backpacking, I think. The qualities that make a good pillow are diametrically opposite to the qualities of good bike packing kit!
As above, use clothes. Not very comfortable, but it's just one thing in the list of things that aren't very comfortable 🙂
Posted : 06/06/2016 1:23 pm
Dry bag stuffed with whatever's to hand/left over. If needed then shoes/boots underneath the dry bag to lift things a bit higher.
Posted : 06/06/2016 1:26 pm
I often use a vango half moon pillow, which fits nicely into a sleeping bag hood and stays in place. However, as said above, it's just not cricket if you carry such luxuries. Dry clothes in stuff sack
Posted : 06/06/2016 1:38 pm
As above, stuff a dry bag with whatever's soft and not being worn. A down jacket in a dry bag makes a very luxurious pillow.
I don't like that bouncy feeling either, so don't close the dry bag, or squeeze most of the air out and don't roll it too far down.
If you've got enough spare clothes, put the whole thing inside a t-shirt or similar so you're resting your cherubic rosy dimpled ones on soft fabric rather than bare dry bag.
Posted : 06/06/2016 1:44 pm
Or old school scout trick ,stuff bag full of bracken/grass/hay in the absence of thick fleece.
Posted : 06/06/2016 3:08 pm
Oh, I like that idea!
Posted : 06/06/2016 3:15 pm
