Any suggestions? Would prefer the (quality) cheaper options than the expensive pro versions....
Cheers for any help...
The wheels mfg bearing drifts/spacers are a fairly easy way of buying exactly the sizes you want. Then add a press with the right size threaded rod and you're there (I had one already that fitted).
I bought individual ones from here- [url= http://www.singletrackbikes.co.uk/ ]singletrack bikes[/url]
[url= http://www.ebay.co.uk/itm/201312710139?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT ]alu bearing press plates[/url]
i use these and an appropriate piece of threaded rod for the most part.
I've used a socket set and screwed rod for years with no problems.
+1 wheels mfg
great tool
