who's got what?
Same as I always say, Gore sealed. Had 'em on my bike for 2 years, not had to clean cables or adjust the rear mech in all that time.
A
Shimano XTR everytime
Cheapo generic cables - last a couple of years or more. Simple to fit, cheap to replace. They just work
If it ain't broke don't fix it / why reinvent the wheel / KISS
SP41 cable (xtr) a 10m reel from Parker international.
I would say XTR as well as the Gore ones as soooo expensive. The Gore one did last a long time IMHO - get a long real of outer SP41 as it works out cheaper 😉
Anything really, it's just wound steel cables. Outers, I use SP41, but pretty much anything will do, as long as it's set up right, and you give it a squirt of lube every now and again, should last a couple of years as TJ suggests.
Full length outer have been a revelation for me, fit and forget, but as its time to replace mine now, I bought some nice looking fibrax braided cables from CRC (only a fiver) and some Middleburn cable oilers to make it really last.
On the other bike that has 3 peice cables I have not swapped to full length as yet, (though I might) its had XTR on it, and has lasted well, but do need a little TLC if been sat in the shed a while after a wash.
Gore Ride-Ons. Take a bit longer to fit but last forever.
the bf and i use flying snakes, brilliant if you cant run full outters but watch out near your frame as the outters are strong as nails and will rub through your paint rather quickly!
Shimano XTR... Though the kit isn't great for full outers, because they stupidly pre-cut the hose. I'm yet to find out how long they last, put it that way.
Another vote for Gore Ride-Ons - I set mine up sometimes last spring and not had to touch them since. The only potential downer is that if you have to change your shifters, you could have to re-cable the whole length (which is a bit pricy with Gores)
So there we have it the definitive STW answer, buy the cheapest, most expensive, full outer, split gear cables, with and without a liner and you cant go wrong! Sheesh!
shimano XT off the reel, full length outers.
fit
and
forget
after seeing power cords, have wondered about some high strength fishing line with a knot in the end, would have to be a static line though to avoid stretch, anyone know owt about fishing?
wikipedia says it would need be superline multi filament stuff to not stretch and remain thin
breaking strength for shifting?
looks cheap, won't rust, stuuuuuupid light
Gore ride on have been great on my bike and have had no issues
In the end i went for the CRC deal - prelubed xt outers in 60cm lengths ( 4 needed) for £1-75 and an XT inner. A complete XT gear cable set for 9 quid!
Brand X teflon coated cables and XT outers. Never noticed much difference between brands but this has worked for me. Run full outers so no worries about mud or water getting in.
[url= http://cgi.ebay.co.uk/10-x-JAGWIRE-cycle-GEAR-INNER-CABLES-with-End-Crimps_W0QQitemZ200354265162QQcmdZViewItemQQptZUK_sportsleisure_cycling_bikeparts_SR?hash=item2ea60b784a&_trksid=p3286.c0.m14&_trkparms=65%3A15|66%3A2|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50 ]10 fibrax inners and end caps for £6.50[/url]
