Recommend me a whee...
Recommend me a wheel truing stand
7 Users
I have a Tacx Exact, which has worked more or less fine. However it's a little bit broken but more significantly it can't do thru axles. I could buy an adapter for £55 (nearly the cost of the stand itself) or buy a new one, which prob makes the most sense. Can you get a reasonable stand (ie better than the Tacx) that can do thru axles for ~£100, or do you need to spend the megabucks? What's out there?
Posted : 20/07/2022 8:50 pm
Ps I have neither bench vice nor a work surface to bolt it down on to
Posted : 20/07/2022 8:52 pm
All you need is something long enough to go through the thru-axle and the truing stand fork things and for this to be able to provide a light clamping action. A bolt or QR skewer or whatever works. It's not like there's any significant forces acting upon it while you true a wheel.
Posted : 20/07/2022 8:58 pm
I just bought a 15mm to qr adapter from aliexpress for when I need to true something. Never used it yet, but it should work.
Amazing, thanks!
Posted : 20/07/2022 9:09 pm
How about something a bit different that needs zero bench space
That's how I started out building my wheels, but using a pen and a rubber band instead- even cheaper! The wheels built up fine as well tbh. I was planning to use this if I couldn't get the truing stand to work...
Posted : 20/07/2022 9:11 pm
I’ve got the exact same stand you have and done qr hubs, 15x100, 15x110, 12x142 and 12x148 hubs. The boost rear is a bit of a stretch but do-able. Don’t think you’d get a superboost hub in there but they’re pretty rare.
I use this adapter for any 12 or 15mm hubs:
https://www.ebay.co.uk/itm/125424373117?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=qkycycpctam&sssrc=2349624&ssuid=P8vL0CMYTrq&var=&widget_ver=artemis&media=COPY
Posted : 20/07/2022 9:14 pm
That looks very useful!
Posted : 20/07/2022 9:17 pm
Amazing, thanks!
Seems a little sarcastic. But don't take my word for it that you don't need adaptors. I only read it in Roger Musson's wheel building book, and what does he know!? See here also:
https://singletrackmag.com/forum/topic/wheel-truing-stand-that-does-12-15-20-out-of-the-box/#post-12360563
Posted : 20/07/2022 9:36 pm
Nope, genuinely grateful for a really helpful tip. Sorry it came across as sarcastic
Posted : 20/07/2022 10:33 pm
 feed
I bought this during one of the crc sales, was about 50% off rrp
https://www.chainreactioncycles.com/ie/en/lifeline-pro-mechanic-wheel-truing-stand/rp-prod122322
Very good stand (even for full rrp). I just use the wheel axle of whatever wheel I'm truing, no adapters, works fine.
Note: comments say it doesn't do 148mm hubs but with a very small amount of persuasion they will squeeze in.
This is 20x times than the park tools TS-8 truing stand it replaced which sells for the same amount.
Oh, and it's stable enough to just sit on any counter \ table top without being clamped or screwed down.
Posted : 20/07/2022 11:40 pm
 feed
Too late to edit: 20x times better......
Posted : 21/07/2022 12:11 am
Not my photo
I've got an on one jobsworth stand I could part with.
It's well used and has been altered to take boost hubs. Works fine, but the bolt holding the truing arm has got bent. Functions fine.
£30+ post? It is heavy.
Posted : 21/07/2022 6:56 am
