Recommend me a Pres...
[Closed] Recommend me a Press Fit bb 92mm
7 Users
Have a Salsa Horsethief frame coming and it uses a PF92mm bb, I've no idea what to order as I would like to have a new one fitted before building up the frame.
Any help would be greatly appreciated.
Posted : 27/02/2016 9:58 pm
Xtr one has been most reliable so far, initially had a gxp that got crunchy quickly, then a token one, xtr has been thru loads of filth still fine
Posted : 27/02/2016 10:13 pm
Have a CK one in mine, but if I were buying now, I'd get the newish Wheels Mfg one that threads together - creak free and bearings are assured to be parallel, so should last well.
http://wheelsmfg.com/bottom-brackets/bb86-92/bb86-92-bottom-brackets/bb86-92-outboard-abec-3-bb-for-24mm-shimano-cranks-black.html
Posted : 27/02/2016 10:15 pm
Looks like the wheelsmfg one is the business!
Posted : 28/02/2016 12:59 am
it's the age old BB question. Buy cheap and often or take a punt on something that will probably last longer but at a price. I've not really solved that one personally, and I suspect the £ per mile is roughly similar. One bike has an Enduro BB (same bearings as the wheelsmfg one but placky cups) and the other runs a cheap Shimano.
Posted : 28/02/2016 8:01 am
If you're using 30mm cranks then I've only managed to find one company that makes BB's to suit a PF92 frame and that's Rotor.
I've been looking around for something else to try as mine's dead but not having any luck.
Posted : 28/02/2016 8:52 am
Hope make a bb92 compatible bottom bracket for 24 and 30mm axles.
The bb92 is pf41.
http://www.hopetech.com/product/press-fit/#tech
Posted : 28/02/2016 9:23 am
Wheels Mfg make a bearing kit for 30mm axle cranks too. Outer race of the bearing has a flange to eliminate the need for a cup. Makes the ball size as large as possible. Double row cartridge too.
I'd fit a 24mm crank with the BB I linked to previously though.
http://wheelsmfg.com/bottom-brackets/bb86-92/bb86-92-bottom-brackets/bb86-to-30mm-flanged-dual-row-pressfit-86-92-abec-3-bottom-bracket.html
Posted : 28/02/2016 9:58 am
As do Hope, well technically Enduro make the bearings.
Posted : 28/02/2016 11:22 am
So they do! No additional seals like the Wheels Mfg one though?
Posted : 28/02/2016 11:28 am
Salsa recommend a BB with plastic cups so will need that type.
Posted : 28/02/2016 8:59 pm
XTR then. Mine's an alloy Split Pivot version, so alloy cups are fine.
Find warnings about not using alloy cups in carbon shells a bit worrying TBH. Odd that alloy headset cups are OK, but not BB cups?
Posted : 28/02/2016 9:06 pm
The Salsa Horsethief frame coming is also a split pivot alloy frame but I'm sure I read on their site to use plastic cups?
Posted : 28/02/2016 9:18 pm
No reason for that. No problems with CK cups in mine. They were a reassuringly good fit too, as the Bb was post-weld machined.
Suspect the plastic cup advice is a copy and paste recommendation from the Carbon version. Never heard of all frames having an issue, but both Ibis and Yeti (neither of whom have a great build quality rep) say to use plastic cup BBs in their Carbon press fit shells.
Posted : 28/02/2016 9:23 pm
Great I think I'll plump for the wheelsmfg one
Posted : 28/02/2016 9:44 pm
