recommend me a pann...
recommend me a pannier rack for a bike without ant fixing lugs
8 Users
1 Reactions
I am looking to attached a pannier rack to my bike so I can use it to go shopping, it will be more of a milk and that nights dinner shop rather than a whole weeks shopping.
the bike has no fixing lugs so what can racks do you recommend
Budget of about £30-40,
Posted : 06/03/2025 3:04 pm
i used to use a Topeak beam rack for commuting which just fixes to the seatpost.  Not much good if you have a dropper / carbon post but otherwise good for light loads.
Posted : 06/03/2025 3:07 pm
cheap rack and then use 'P' clips on the seatstays.
Posted : 06/03/2025 3:20 pm
Sounds like the bike is the problem, @stevie750. You'd better buy a new one that has the required mounting points. 😀
Posted : 06/03/2025 4:21 pm
Not the cheapest but a well regarded option
Ortlieb Quick Rack
Posted : 06/03/2025 8:19 pm
https://www.sjscycles.co.uk/luggage/topeak-front-basket-with-fixer-3e/
Posted : 07/03/2025 8:35 am
https://www.freewheel.co.uk/m-part-seat-clamp-with-rack-mount-black-varspt1
Use one of theses and P-clips by the axle?
Posted : 07/03/2025 12:35 pm
Yep, just get the ones that closest match the diameter of your frame or go up a size and wrap the frame in tape.  The ones I used were plastic coated rather than having a separate shim like that one, not sure if that might shift about a bit?  An I added a bit of protective tape under it to stop it wearing the frame.
The seat clamp one Jameso linked to works best at the top though.
Posted : 12/03/2025 12:01 pm
stevie750 reacted
