Recommend a single ...
[Closed] Recommend a single speed conversion kit
6 Users
Going to give single speed a go on my Jack Flash when I get it built up.
Having never done a single speed conversion what do people recommend for rear hub and tensioner?
Rear wheel is a Superstar with 10spd Shimano free hub and QR axle.
Also chain ring for the front - will a normal n/w be ok? (Have a spare in the garage).
And what chain can I get away with? Have a spare 7/8 speed in the garage.
Posted : 14/01/2021 6:57 pm
The chain and ring you have will be fine.
Don't buy a "kit" they're always cheap sh1t.
Get a spacer kit from velo solutions or used if you can.
Rear sprocket, I always use surly and they're often 2nd hand on eBay but the truth is any sprocket with a wide base will be fine.
The wide base stops it eating your freewheel.
Add a gusset tensioner and you're good to go.
Posted : 14/01/2021 7:05 pm
Yeah, as above, kits are generally shite.
Buy spacers, or break down old cassettes for them.
Surly cogs are probably the best, but the wide base ones from On-One are good too.
Existing chainring fine, but I might buy a 7/8 spd chain, as sometimes the teeth on Surly cogs areba little wide for 10spd+ chains.
Many tensioners out there, but I'm a fan of double jockey wheel ones like Paul's or Rohloff. They just work better.
I've always had issued with the single jockey wheel type, though YMMV.
I know some people have had good luck with BB mounted tensioners.
Posted : 14/01/2021 7:17 pm
Just de-SSed my fat bike. I'd used a normal cog as I didn't have a wide base to hand and it had really dug into the freehub (Industry Nine) and took quite a bit of removing.
NW chainring will be fine. I used a tensioner I'd got from CTBM.
Posted : 14/01/2021 7:31 pm
Have a browse here - https://www.velosolo.co.uk/shopsingle.html
Posted : 14/01/2021 8:00 pm
Thanks all.
What about this kit from Gusset - includes a 7mm base on the sprocket.
https://www.gussetcomponents.com/shop/hubs-and-cassettes/double-six-converter-16t/
Am I better going for a spring tensioner or bolted type?
Posted : 14/01/2021 8:17 pm
If you've got ISCG mounts, something like a Blackspire Stinger is a neat solution. I run one and it's easy to make tension adjustments. Although as I'm learning, provided you've got a decent SS-specific chain, ring and sprocket, you're better off running the chain on the slack side. It won't drop.
Posted : 14/01/2021 8:30 pm
