Reccomend me a torq...
[Closed] Reccomend me a torque wrench
9 Users
Need one for my bottom bracket...
Posted : 19/11/2012 9:25 pm
What, for the cranks?
Posted : 19/11/2012 9:31 pm
Doh!
Yes for the cranks!
Posted : 19/11/2012 9:48 pm
bottom brackets do have a torque setting though no? Seem to think something like 55Nm (or is that something else?) so loads. Loads more than I'd ever crank up with a BB tool so never bother
For crankarms, stems, brake *calipers, etc I'd reccomend what I have, the BBB one for about £50 or so. Came with a decent selection of bits that have yet to show any sign of rounding at all, goes down to 2Nm and the box is quite useful
*brake and gear levers I can't see the point of torquing, nor doing tight. I do them just nipped enough that they won't move when operating, that way when I crash they spin around instead of being the taking the brunt of it. Plus I can tweak them pootling along flat stuff
Posted : 19/11/2012 10:25 pm
By cranks do you mean Sram/Truvativ types that need a torque setting upwards of 40Nm through the 8mm hex bolt or do you mean square taper crank arms with the central M8 bolt or do you mean bog standard fit n' forget Shimano x2 M6 pinch bolts in the non drive side crank arm @ 12-14 Nm, if it's the latter then [url= http://superstar.tibolts.co.uk/product_info.php?cPath=36&products_id=550 ]I recommend this one, perfect for every torque setting on your bike[/url] and it's the same as many others costing far more.
Posted : 19/11/2012 11:03 pm
You dont need a torq wrench for the pinch bolts. Just tighten them equally in steps until your elbow clicks. That'll be tight enough. Its about 14nm for pinch bolts which is alot.
FWIW the only application they are good for is carbon on carbon. If you feel you want one then BBB do a very good one.
Best of luck
Posted : 20/11/2012 7:42 am
I have a surplus park tool one. It's the high range one, I wanted the low.
Posted : 20/11/2012 8:04 am
I've got a Halfords Professional one. Very good, but only goes as low as 8Nm.
Posted : 20/11/2012 8:05 am
I've got one of these: http://www.chainreactioncycles.com/Models.aspx?ModelID=60766 and can't recommend it enough. I had a bargain too as someone was selling it for £30 🙂
Posted : 20/11/2012 9:16 am
i got one from superstar for £35 which seems the same as all the ones like bbb which all sell for £50 odd
Posted : 20/11/2012 9:42 am
I'd sell my park tool for £30
Posted : 20/11/2012 11:30 am
I've got two Sealey ones. a short stubbier one for light torquing and a much longer one for stuff like BB's and cranks.
Posted : 20/11/2012 12:30 pm
jkomo - Member
emailed you.
Posted : 20/11/2012 12:44 pm
