Reccomend me a GPS ...
[Closed] Reccomend me a GPS mapping unit for cycling use here and in the USA
10 Users
Evening all,
I'm very much a map and compass navigator and have never seriously used a GPS but in planning a trip to Colorado this year it is becoming increasingly apparent that I'm going to spend a lot of time wrestling with unfamiliar maps in areas I have no knowledge of (and may get shot/eaten if I stray from the trail) and I'd also rather not spoil the flow of the trails.
Would anybody be able to recommend a GPS unit that will allow me to follow a pre-programmed course/route, will work over here and in the US, and provide appropriate grid references for a paper map? Ideally I'd like one that will mount on the bike, give altitude and also show a map, but giving me directions and coordinates are the main criteria.
Being a proper outdoor unit (waterproof, shockproof, etc) and taking standard size batteries would also be a help for emergencies rather than USB charging or non-removable battery. I'm not bothered about updating my position to MyTwitFaceTubeBook, Strava based willy-waving or other electronic frippery, I want a solid navigational device first and foremost.
Please tell me what I need to know,
Much obliged in advance,
S
Posted : 12/02/2014 11:49 pm
Apologies for the typo in the title!
Looking at the new etrex 30, it seems to have everything I would like. Any opinions on the unit gratefully received.
Cheers,
S
Posted : 13/02/2014 7:23 am
bump for the evening crowd.......
Posted : 13/02/2014 7:10 pm
 Chew
Dont have an etrex, but i have a Garmin Dakota can cant fault it.
It runs on AA batteries and i'll get between 1-3 days of riding from a set depending upon temperatures.
The screens of a reasonable size to see what you're doing and the touchscreen works fine wearing normal winter gloves.
If you just by the unit you'll need base maps for the UK and US.
http://www.ioffer.com/i/garmin-uk-gb-discoverer-1-50k-v3-00-2012-full-map-sd-523378201
£20 UK version here which people recomend, and i'm sure there will be something similar for the US
I believe the Garmin may give you OS Grid References for other mapping, but GPS's work on Lon/Lat ordinates which are more useful if you ever needed to be rescued.
Posted : 13/02/2014 7:51 pm
I also have a Dakota which I have used here and in Colorado. The link Chew refers to had US maps last summer for ~£25
Posted : 13/02/2014 7:56 pm
Garmin eTrex Vista or Edge 810/810.
Posted : 13/02/2014 8:00 pm
Much obliged, will look into those options.
Thanks,
S
Posted : 13/02/2014 9:57 pm
Etrex 30 here
Does everything that I need and does barometric altitude
AA batteries a bonus, you can buy them in most places
I prefer to plan routes on the PC and then upload to a micro SD card
Posted : 14/02/2014 5:20 am
Shackleton - this is an excellent phone app for Colorado and other US routes, maybe use together with you new Garmin?!
www.mtbproject.com
ps- I use a Dakota too.
Posted : 14/02/2014 8:07 am
I was talking to the Garmin guy at the bike show yesterday and was keen on the Oregon 600 for this type of thing. Worth a look.
Posted : 14/02/2014 8:43 am
eTrex 30 is going to be my next purchase, to replace an old eTrex Vista HCx.
AA batteries more than just a bonus. Always have a spare pair in camelbak.
Mapping... I use OSM which takes a little bit of effort, but is free. More than adequate around here, but no idea about Colorado. Never used Garmin paid-for maps.
Coordinates... you can set all kinds of grid references and datums on them.
Routes... I plan on a PC (via a bit of a manual process) then transfer. On Vista you send routes, waypoints etc. over the USB connection, but maps and gpx track via the SD card. Bit strange, but maybe newer eTrex are a bit more sensible?)
Posted : 14/02/2014 9:07 am
Toughened Smartphone, decent navigation app (I use AlpineQuest), all the maps/satellite images you need on an SD card, take along a usb power pac /solar charger... why would you need a GPS as well? I am guessing you will have a mobile phone anyway?
Posted : 14/02/2014 10:00 am
 PJay
I've just got an Etrex 30 (although it's yet to go out on the bike due to all the manky weather). It's a general purpose unit and great for walking/geocaching as well as cycling (the Profiles feature lets you set up the unit for multiple uses including marine usage). It'll do proper route finding (and the free OSM routable maps can be used for this) and is a fair bit cheaper than the Edge 800 range which, you'll probably only want if you need the training features (I have an old Edge 2 but turned the training assistant off).
Despite not being a cycle specific unit you can connect up an ANT cadence sensor (heart rate and temperature too) if you want too and handlebar mounts are available.
I think that the Etrex 20 is the same but without the barometric altimeter and electronic compass.
A word of warning though; beware the absurd licensing restrictions for Garmin's own maps. If you buy a map on micro SD card it's locked to the card (mine came on a tiny 2 Gb card when the unit will take a 32 Gb one) and can't be copied elsewhere; if you buy a download then the map's locked to your specific unit and can't be transferred to another one.
Posted : 14/02/2014 10:20 am
 Chew
Mobile phones need to be in reach of mast signal to be able to triangulate there position. Thats ok if you'll only be riding in areas with good signal, but not really suitable if you're going to be riding somewhere more remote.
Posted : 14/02/2014 11:54 am
Sorry, that is rubbish. All modern smart phones have a GPS chip in them, exactly the same as a Garmin, and in some cases far better. The GPS funstion will work anywhere in the world where there is a view of the sky (or not once they have a fix).
Posted : 14/02/2014 12:15 pm
 PJay
@ andytherocketeer, the Etrex 30 presents itself as a USB mass storage device for drag and drop transfers; if there's a micro SD card fitted then this shows as a second mass storage device (so it's really easy to drag and drop between the two or back and forth from the computer).
I would assume that Base Camp/Tracklogs etc. would transfer directly to the Garmin, although I haven't tried this yet.
One downer on an otherwise great product is that the USB connection is still version 1 and copying a 600mb OSM map across can take around 10 minutes.
Posted : 14/02/2014 12:22 pm
agentdagnamit - cheers for that, I'd been using the web site but hadn't realised there was an app too. Thanks very much! I will shove it on my tablet.
Everyone else, thanks very much, a lot of useful info there to mull over, particularly from Pjay and andytherocketeer on the etrex30. I don't yet have a personal smart phone so that option is not open to me (sorry welshfarmer, my bad) unless things change over the next few months. I'm still using a £5 PAYG Nokia from car phone warehouse.......
Posted : 14/02/2014 11:30 pm
Smartphone battery life is limited when GPS-ing
Etrex 30 connected via USB is comparatively slow. I keep maps, routes, etc on microSD fitted in the Etrex. I plug the microSD directly into the PC for transfers, there are various USB-size and SDcard-size adaptors out there for not very much money
Posted : 15/02/2014 6:20 am
Cheers Timba, useful advice.
Posted : 15/02/2014 9:42 am
