rebuilding LB rims
[Closed] rebuilding LB rims
7 Users
 DT78
anyone tried.  did they lace back up again ok?
potentially swapping out a frame which has 148 boost thingy which means my CK hubs at 135 don't fit.
Posted : 21/10/2018 6:57 pm
Can’t you just get a spacer kit?
Posted : 21/10/2018 7:58 pm
Did it with my 27.5 lb 38mm rims, well, got lbs to do it, no issues, used same spokes and nips.
Posted : 21/10/2018 8:10 pm
Mine were rebuilt a few times due to faulty dynamo hubs. Not by me but apparently no issues during the build and they’ve been fine for several years of use since.
Posted : 21/10/2018 8:12 pm
 DT78
good to hear the rims rebuild fine, as I really like mine and they are in great nic.
spacers wise, I don't think you can, and tbh I'd rather have a hub that fits the frame properly if I can
bonus question - is a 110 front hub a boost ?  Is that also bigger than an 'old' hub (100 wasn't it?)
Posted : 21/10/2018 8:20 pm
Yeah, that's correct DT, 100 was 'old' and 110 is boost.
Posted : 21/10/2018 8:25 pm
Mine rebuilt just fine when I swapped hubs.
Posted : 21/10/2018 9:34 pm
They build like any other rim- except that they're bloody stiff, which makes it easier to build but also makes it possible to build really really badly and still have a functioning-ish wheel. I reckon that stiff rims make it a little harder to actually build a good wheel because of that temptation and the increased difficulty of diagnosing- building with my floppy XC rims told me exactly when I had it right or wrong.
But other'n that it's no fuss
Posted : 21/10/2018 10:40 pm
