Reberb setup, hose ...
[Closed] Reberb setup, hose shortening and bleeding
7 Users
After discovering that my temporary seatpost on my BFe (i.e. the seatpost pinched from my wife's bike) is too short, I've hit the expensive buy button on a Reverb from Merlin. Hoepfully it will be here before the weekend so I can ride.
As the Merlin kit doesn't come with the bleed kit etc, should the Reverb work straight from the box without needing a bleed, or have people been finding that it needs bled before the first ride? I'm hoping I can just fit it and ride for this weekend, and bleed next week.
Turning then to the hose shortening and possible bleed, I don't want to pay silly money for the Shimano kit. I have screw in syringes from Avid brakes which I think should work if a bleed is required. Where is good for getting the new barb and a small amount of suitable oil? Anything else I'll need?
Thanks
Posted : 29/08/2012 8:59 am
Youtube it for the shortening proceedure.
You don't need a bleed kit or any bits to shorten the hose (unless you're an idiot who can't follow the simple instructions!)
Any 2.5wt suspension oil is fine. CRC were doing half a litre of Stendec oil on sale last week for about 3 quid.
Posted : 29/08/2012 9:04 am
Excellent, thanks. I'll try shortening it and only buy the oil if it goes tits up then.
Posted : 29/08/2012 9:08 am
I've shortened the hoses on two Reverbs and not had to bleed them. These guys do cheap bleed kits should you end up needing one... http://www.epicbleedsolutions.com/products/bleed-kits/rockshox/reverb/complete-kit/
Posted : 29/08/2012 9:18 am
didn't need to bleed mine when i shortened the hose. Follow the Rock Shox how to videos.
Posted : 29/08/2012 9:20 am
Shortened mine without bleeding.
2012 posts don't need a new bard, the remote button unscrews, cut carefully so as not to spill fluid and screw back in.
Posted : 29/08/2012 9:31 am
about to jinx it, but my reverb has worked straight out of the box..... never had to do owt.
Even when I shortened the hose, followed the how-to vid and it worked perfectly, no bleed required.
Posted : 29/08/2012 9:33 am
Thanks all, sounds promising
Posted : 29/08/2012 9:49 am
You can get the kits from eBay for £14.99 posted. I've just got one and looks ok to me.
Posted : 29/08/2012 11:26 am
