Reba.....Changing t...
[Closed] Reba.....Changing travel.....How straight forward?
7 Users
I have a 2009 Reba SL that is currently set to 100mm.
How straightforward is it to increase the travel to 115mm?
What special "bits" would I need?
Posted : 22/02/2010 12:59 pm
Easy but 09 Rebas have 20mm spacers
Hmm okay.
Mine may be a little older then as I am sure they are 80/100/115.
Either way are the spacers accessed by taking off the lowers?
Posted : 22/02/2010 1:03 pm
Yes. Some will say you can poke the air rod through the top of the leg but I couldn't.
Lowers off, circlip removed from bottom of leg, remove air rod assembly, remove spacer, re-insert air assembly, refit lowers, oil.
Posted : 22/02/2010 1:05 pm
5 min job dead easy
Posted : 22/02/2010 8:10 pm
thwang-01 - Member
5 min job dead easy
Tell me more.......
Posted : 22/02/2010 8:14 pm
easy - I managed to pop air rod through top of fork leg. 5 minutes, and some fork oil.
peter poddy has the guide you need.
Posted : 22/02/2010 8:30 pm
While we're on the subject, where do you get the spacers from/ I have a Reba Team set at 115 which would be happier at 100mm for the Maxlight XC pulling behind it.
Posted : 22/02/2010 8:59 pm
If the forks are OEM you probably won't be able to increase the travel. I had some '09 ones which came on a Rockhopper Pro and I had a go but it couldn't be done.
I didn't need to take the lowers off to get at where the spacers go though - popping the rod through the top worked fine.
Posted : 23/02/2010 9:23 am
Email me, (In profile) and I'll foreward a step by step guide for you. It's a piece of cake to do. 🙂
Posted : 23/02/2010 9:40 am
Actually don't email me, try this link instead! 😀
https://docs.google.com/fileview?id=0B1AoGIWBz4H1M2E5ZTc0MTItNjM4NS00YjBiLWEwZDgtMjEyYTQ5NWZlMjc5&hl=en
Posted : 23/02/2010 9:50 am
