I remember reading somewhere how to let air out if chambers get 'confused' , somewhere up the base of the air side lower is there a Schrader valve ? 2013/14 version. Ta.
On my 2014 Revelation there's a Schraeder valve inside the left leg. Unscrew the bolt securing the lowers and you'll see it.
Ah, that rings a bell, cheers
There is - it's hidden under the foot bolt on the air side. Undo the foot bolt, and shine a torch in there - the core of a schraeder valve is hidden in the air shaft. Depress it and be ready for a little bit of oil to be shot out!
EDIT - beaten to it!
Thanks both, and yes I did edit my left and right 😆
