Reba RL - Travel ch...
[Closed] Reba RL - Travel change 80mm to 100mm
5 Users
 Yak
I've got an 80mm Reba 29er. I reckon I could do with upping to 100mm. So whipped the spring out thinking I could take out a spacer to get it up to 100mm. (Stanchions have 80/100/120 markings). But no spacer, so it's a fixed 80mm spring.
So I assume a 100mm air spring assembly is all I need? But will I also need to swap the damper?
Edit - just had a thought - presumably I just need to measure the length of the existing damper shaft to see if it had been running compressed at full extension or not. [thinking out loud. Should think before I post! 🙂 ]
Posted : 08/03/2017 10:17 am
Like a proper coil spring? I'd have thought the other springs would have been on the push rod below the stancion.
Posted : 08/03/2017 11:26 am
You need a new air shaft. Look for the number on the rockshox parts catalog and order from tf tuned / amazon etc
You don't need to swap anything else.
Posted : 08/03/2017 11:33 am
 Yak
Thanks. Air shaft only then. Good - was hoping it would be a cheap fix.
mtbfix - no I meant the air shaft, seals etc that make up the air spring.
Posted : 08/03/2017 11:39 am
Good luck sourcing an air shaft ! SRAM quoting 4 to 5 weeks , LBS got me the only one they had left at TF turned out to be the wrong one ! Mine are 2012s seems that was a redesign year and price is up round £80!if you can get one !
Posted : 08/03/2017 11:48 am
 Yak
£80!! 😯 . Was hoping for about £25 or so. Will get searching then.
Posted : 08/03/2017 11:52 am
what year Reba? I am just about to order a 120mm airshaft to replace the 100mm on my 2013 solo air. They are around £20-25 normally for the solo air shafts. You dont need the whole assembly with the seal head etc.
Posted : 08/03/2017 11:57 am
 Yak
Posted : 08/03/2017 12:01 pm
Mine were dual air 🙁
Posted : 08/03/2017 12:04 pm
 Yak
Yes - just checked in the catalogue. That's the one. I'll order now.
thanks.
Posted : 08/03/2017 12:26 pm
just putting an order through myself but will be held up by the Pike air shaft and spare seal head being out of stock. Postage isnt bad though at about £6.
Posted : 08/03/2017 12:41 pm
 Yak
Try bike24 if you are struggling.
Posted : 08/03/2017 12:44 pm
yeah they have some stuff too. Just got my damn spokes from them! Typical.
I normally order my fork spares from Gabelprofi
Posted : 08/03/2017 12:46 pm
