Need Help 🙁
I added a 10 mm spacer to my Rebas and now they won't hold and +ve or -ve air.
The forks are 1 year old so I though a seal my be faulty, so I've changed the seals but the fork is still leaking air.
I've checked the top cap valve as well and that is not leaking - so where is the leak coming from?
Spent all weekend trying to sort this and I getting very peed off!
Why do you think they are leaking? Apologies if I am stating the obvious , but if you pump them up to say 100psi, then take the pump off, then reattach the pump they will no longer be at 100psi as some of the air has escaped into the pump
My dog's called Reba, seriously !
I was wondering what the smell was
