I have some rock shox reba forks 2010 and when you compress them quickly and let the fully extend there is a clunk noise ! is this normal
cheers
Rich
Any one?
How much rebound have you got on them?
A little , the rebound does work from super fast to real slow
nope.
Are your air pressures right?
Rebound set too on max?
Is it a dual air model, or a solo air?
Might just be that you have no air in the negative chamber if it's a dual air fork.
If its a solo air model then you may find that you need to renew the seals in the air chamber.
Also worth checking is that you have the rebound adjusted correctly (dial at the bottom of the right leg)
Hope this helps.
Robin
Does it still clonk with more rebound? Does it clonk if you just push and pull it slightly or only on full return? Does it clonk midstroke or only at the top?
I have 120 psi in both pos and neg chambers do it is a dual air , might phone tf tomorrow 🙂
Only at the top when I compress the fork very quickly and pull up on the bars
evans suspension - Member
[i]Is it a dual air model, or a solo air?
Hope this helps.
Robin [/i]
Reba's are dual air, they have never done a Solo air version...
Hahaa good point!
I had a similar issue with my rc41's. Turned out the oil was a few mm low in the damper leg. Topped up oil and pumped it a few times. job done.
