I bought a new (2013) Reba RL Solo Air a few weeks back, however after a few rides I found a crack opening on the top disc post mount. It went back to shop and on to Fishers, who have advised :
Lower leg replaced under warranty from stock fork. This is a SID upgrade. Fork tested and returned in full working order.
Not really sure what this means by way of upgrade, but I guess sounds fair ?
Any thoughts ?
I guess you've now got SID lower legs - probably a bit lighter.
Need you know more?
EDIT: ^ Hmm, may sound a tad harsh. I'd say a win and good job fishers.
I'd be very happy with that and good service by Fishers.
The lowers are the same starting from 2013-ish, so the only upgrade you got is the stickers :).
"9. 2013-2014 Reba and 2013-2014 SiD Solo air internals, CSu and Lower Leg assemblies are interchangeable."
thanks all, happy with the solution and the service, useful to know that they are similar/the same and interchangeable.
Thanks to both Fishers and Winstanleys - can't fault the process.
