Just reinstalling the rear shock after servicing the fun bits. When I get anywhere near the specified torque at the front mount it gets really tight and the shock doesn't hang down, but is held up. I can't remember whether this was the case when I took it apart.
Should there be more freedom of pivotness than this?
It's a Rocket 275, if it's a specific issue
Gut instinct, yes it should be able to move more than that. Certainly does on my fs.
If it's a du Bush your using the there's plenty enough friction to hold a shock up. It would be normal. If you want it to run freely you need some sort of bearing in there, either a needle roller or bearing mount shock even better (but that's something that must be designed for up front)
Thanks for the input. The shock doesn't pivot very much on compression anyway and was fairly easy to move by hand, can't imagine a great deal of wear will occur so long as I keep it greased.
I'm sure I read somewhere that you don't grease du bushings? Might be wrong though.
This I do know.Lol
You don't lube du bushings as said above.👍
I had this on a new 2012 Orange5 frame, used theses to good effect.
Need a regular service in winter though
DU bushing? I don't think it is, it's brass or bronze or something. Unless that's what a DU bushing is, in which case I should probably get the iso alcohol out.
You wont get much rotation at that front shock mount.. so needle bearings are pointless here.
I'd certainly explore needles on the swingarm end if you are a really light rider though or super sensitive to stiction.
tolerance is a factor here, even with the lowest friction bearings/bushings, you could still bind things up if your end reducers are being forced against the shock eyelet when tightening.
I'm not light by any stretch. There's not a great deal of movement at the swingarm end either.
I'll try again getting in touch with Cotic to see what they say. Seems a bit tight, but not sure what's changed if anything.
Going Woody's again in a couple of weeks, that'll show up any faults 🙂
