Have had My '13 Giant Reign 2 for two years and done frame bearings,BB etc but haven't done my rear shock mounting Hardware,bushings.I recently bought Offset bushings for my Kona Entourage and when I was doing the bearing on the Reign I was wondering if I would be able to put a set in my Reign too,the mounting kit is obviously different but I'm wondering if the mounting is something that for certain bikes it just doesn't allow offset bushings etc.
Hopefully I'm not asking a nonsensical question
Are you asking if you can put 1 offset bushing in the top of the shock.
If so then the answer is yes you can. 😀
Thanks Rob,would i be able to do one on the bottom also??
Thought it was the point to do offset bushings top and bottom
You don't need to run a pair. You can just run one on it's own. As Rob says - you can't run a lower one on Giant frames due to the Maestro pivot.
People run a pair to get the max adjustment possible when their frame allows.
Your Reign will be using a 6mm bolt though, so you can get more offset than with a normal 8mm offset bushing. You'd be looking at around 0.75 degrees adjustment on average. They're very popular for the Reign / Trance / Anthem actually. You can get them from [url= http://www.Offsetbushings.com ]Offsetbushings.com[/url]
Hope that helps,
Jeron
Cheers Jeron
I've used these on My Kona Entourage and was hoping to use them on my Reign.
What size of Du Bushing do I need
You don't need to change the DU.When you order the offset with 6mm hole and the right width.just state which shock it is for.Fox,RS,CC,etc.Job done. 😉
I think i might have one you can have for postage.Off out now but will look for you later bud.
Cheers Rob,its a Rockshock Monarch rear shock,i need to change it anyway,got small amount of play in it,only just done the bearings so will do the du bushing,was hoping it was same as the Fox Van R as i have some of them but i think its different size,
Bushing you probably want 1/2 inch bushings (its shock dependent). Personally I prefer polymer to DU but you can run either.
So,if im reading this right,i can use the same Eyelet bushings as the ones i bought for my Fox VanR??im sure they were small silver 1/2 bushings,And then order 1 offset bushing for the top which can be more than the usual offset due to not being 8mm bolt hole but 6 mm.
We sell polymer DU bushes in 1/2" for just £2 🙂 they'll ship with any bushings you order.
Hope that helps,
Jeron
