Rear shock length q...
[Closed] Rear shock length question
2 Users
Hi guys.
My bike takes a 222x70mm rear shock that's coil. Finding an air one to replace it doesn't give me many options that are not overly expensive.
How bad would a 215x63mm shock affect the ride? It has a high ish BB so at a guess I would loose a tiny bit of travel and lower the BB a bit.
But is this a really bad idea??
Posted : 24/08/2016 8:27 pm
you would need to test it with no air in first to see if the suspension clobbers anything at full travel. (or a piece of wood with 2 holes 152 mm apart) sorry ignore me I finally got round to doing the other sum 😳
Posted : 24/08/2016 8:30 pm
Cheers for the info.
I kinda figured in a basic way the closed length of the shocks should be the same. Being 7mm shower on the length and stroke.
So should..... be OK.
But will get hold of a shock to try it out.
Posted : 24/08/2016 8:40 pm
